mark235 5 Posted February 11, 2022 Posted February 11, 2022 This feature worked fine in the Shield Experience v8.x, but I can no longer get it to appear in Playback Settings since I upgraded to v9.0.0. I do see the 3 bitstreaming options that normally appear right below this setting (Allow TrueHD passthrough, Allow DTS passthrough, Allow DTS-HD Passthrough). Only DTS passthrough is enabled, per my processor's codec support. No hotfixes are installed yet. I have reinstalled the Emby app but no joy. I have also made adjustments to Shield's Advanced Sound Settings > Surround Sound > Available formats, but this also did not trigger a change. Are there prerequisites to make this setting visible? I depend heavily on it since my Classé processor does not support any HD Audio formats. ffmpeg-remux-b97c2f74-4a8a-4b5a-b238-4ba1375682e8_1.txt
mark235 5 Posted February 11, 2022 Author Posted February 11, 2022 I get sound, but HD formats end up as stereo on my processor. AC3 and DTS are bitstreamed properly. So it looks like the option that downmixes unsupported audio to stereo is active in the background, although that option is also not visible?
ebr 16337 Posted February 11, 2022 Posted February 11, 2022 Hi. Can you please play that item for a few seconds and then follow the instructions to send a log from the app?
mark235 5 Posted February 15, 2022 Author Posted February 15, 2022 Yes, I'll make an attempt to send the log tonight
Solution ebr 16337 Posted February 15, 2022 Solution Posted February 15, 2022 On 2/11/2022 at 4:17 AM, mark235 said: I get sound, but HD formats end up as stereo on my processor. AC3 and DTS are bitstreamed properly. So it looks like the option that downmixes unsupported audio to stereo is active in the background, although that option is also not visible? Can you please try the current beta release of the app? It should expose the audio option for you so you can set it to convert to DD on the server if you wish.
mark235 5 Posted February 15, 2022 Author Posted February 15, 2022 That's great, I'll update and give it another try
mark235 5 Posted February 15, 2022 Author Posted February 15, 2022 hmm, 2.0.66 beta wasn't available yet from the google play store. I'll see if I can install from usb later
Luke 42245 Posted February 15, 2022 Posted February 15, 2022 48 minutes ago, mark235 said: hmm, 2.0.66 beta wasn't available yet from the google play store. I'll see if I can install from usb later Let us know how you get on. Thanks.
