Skyfay 19 Posted February 10, 2022 Posted February 10, 2022 (edited) I've noticed something that bothers me for a while and wanted to report it now. With the IOS apps, if you change the network, Emby stops completely and no longer loads. When you're looking, it stops and no images load when scrolling. To fix this you have to close the app completely and eject it. This occurs when you switch from WiFi to a mobile network, as well as the access point in the internal network. I often notice this at home because I have Ubiquiti access points and they keep switching. Since the IP is changed, the app does not check it and you have to restart it. Would be cool if this could be solved a little more elegantly. RPReplay_Final1644529024.mov RPReplay_Final1644529024.mov Edited February 10, 2022 by Skyfay 1
rodainas 191 Posted February 11, 2022 Posted February 11, 2022 Yes I can confirm this. If you do nothing and keep it open after a certain time it reconnects but it is bothersome. The other way is using the change server option to reconnect instead of exiting the app. 1
Luke 42242 Posted February 15, 2022 Posted February 15, 2022 Hi, yes it does recover, it's just that it often can take a long time. We are working on improving it. Thanks for reporting. 1
