pepinacosplus 6 Posted February 9, 2022 Posted February 9, 2022 Im having a really bad time with Live Tv too, slow loading speeds, not released tuners forcing me to restart every 2 hours, streams not starting, frezees... when i load the m3u file in my pc it tooks like 3 seconds in load the channel... when i load it through Emby it takes like 30 seconds loading and sometimes it doesnt start...
Spaceboy 2573 Posted February 9, 2022 Posted February 9, 2022 1 hour ago, pepinacosplus said: Im having a really bad time with Live Tv too, slow loading speeds, not released tuners forcing me to restart every 2 hours, streams not starting, frezees... when i load the m3u file in my pc it tooks like 3 seconds in load the channel... when i load it through Emby it takes like 30 seconds loading and sometimes it doesnt start... using what client?
Luke 42243 Posted February 9, 2022 Posted February 9, 2022 Hi there @pepinacosplus can we please look at an example? Thanks !
pepinacosplus 6 Posted February 10, 2022 Author Posted February 10, 2022 (edited) thx for reply. Device is not important it happens in browser, windows app, android tv or android phone. I attached a embyserver.txt log. I manage my streams from a Vu+ Duo 4K SE in a streaming panel (that i need to restart every 2 hours to delete the non-released tuners) and then i send the stream to emby in a m3u file. Right now i do not have any stream. But my panel says that i have 2 running to emby server. this happens when the stream do not start in emby server keeping the screen in a eternal loading and freezing the tuner for 2 hours (beacuse i have set it in that time, it can be forever until i restart). With direct m3u file from vu+ duo 4k se openwebif is even worse because i need to restart the entire box to release the tuners. Thats why i use a streaming panel between the box and the emby server. The problem comes when i process the m3u file via Emby, i can open it directly in VLC without issues, locally or externally, in less than 5 seconds without any freeze or tuner problem. thanks. embyserver.txt Edited February 10, 2022 by pepinacosplus
Luke 42243 Posted February 15, 2022 Posted February 15, 2022 On 2/10/2022 at 5:52 AM, pepinacosplus said: thx for reply. Device is not important it happens in browser, windows app, android tv or android phone. I attached a embyserver.txt log. I manage my streams from a Vu+ Duo 4K SE in a streaming panel (that i need to restart every 2 hours to delete the non-released tuners) and then i send the stream to emby in a m3u file. Right now i do not have any stream. But my panel says that i have 2 running to emby server. this happens when the stream do not start in emby server keeping the screen in a eternal loading and freezing the tuner for 2 hours (beacuse i have set it in that time, it can be forever until i restart). With direct m3u file from vu+ duo 4k se openwebif is even worse because i need to restart the entire box to release the tuners. Thats why i use a streaming panel between the box and the emby server. The problem comes when i process the m3u file via Emby, i can open it directly in VLC without issues, locally or externally, in less than 5 seconds without any freeze or tuner problem. thanks. embyserver.txt 5.49 MB · 1 download OK, there's a good chance this is improved in the upcoming 4.7 server release if you'd like to try the beta channel. If you still have issues we can work together there to iron them out quicker. 1
Carlo 4561 Posted March 3, 2022 Posted March 3, 2022 @pepinacosplus Hi, Just wondering if you have you tried the 4.7 beta yet?
pepinacosplus 6 Posted March 7, 2022 Author Posted March 7, 2022 Hi, no, for family reasons o did not have toó much free time to try the beta server. I will wait for a stable release. Thanks for asking. This is not in the topic theme but does emby support clearkey?
