fallenwitch3r 45 Posted February 9, 2022 Posted February 9, 2022 All movie trailers are stuttering on Android TV. First it's loading when I try to play a trailer of my local media files and then the trailer have a bad Quality and is flickering and stuttering. I use Android TV with Android 9 Any ideas how to fix it?
Luke 42245 Posted February 9, 2022 Posted February 9, 2022 Hi there, can we please look at an example? Thanks.
fallenwitch3r 45 Posted February 9, 2022 Author Posted February 9, 2022 (edited) There is nothing more to describe. I think it's a Android TV problem. Firetv, Browser and so on are working well. The stuttering is on all movie trailers and they have all bad quality and flickering. After some time the quality gets better but the flickering and the buffering are still there. It's not possible to record this from screen because you can't see the flickering. Edited February 9, 2022 by fallenwitch3r
ebr 16337 Posted February 9, 2022 Posted February 9, 2022 23 minutes ago, fallenwitch3r said: The stuttering is on all movie trailers and they have all bad quality and flickering. After some time the quality gets better but the flickering and the buffering are still there. It's not possible to record this from screen because you can't see the flickering. Can you please play that item for a few seconds and then follow the instructions to send a log from the app?
fallenwitch3r 45 Posted February 9, 2022 Author Posted February 9, 2022 (edited) I tried three trailers and send you the log through the Android TV App. Did you receive the log file? Edited February 9, 2022 by fallenwitch3r
ebr 16337 Posted February 9, 2022 Posted February 9, 2022 5 minutes ago, fallenwitch3r said: I tried three trailers and send you the log through the Android TV App. Did you receive the log file? Hi. Yes. The trailers you are trying to play are from YouTube. The quality issues could be bandwidth limitations between the device and the source but it could also be that the TV does not have a very good implementation of the technical component we use to play a YouTube video within the app. I'm seeing lots of decoder errors being thrown during playback.
fallenwitch3r 45 Posted February 9, 2022 Author Posted February 9, 2022 (edited) I cant imagine that these problem is a coming from bandwidth. But i have no idea how to fix it.. Edited February 9, 2022 by fallenwitch3r
ebr 16337 Posted February 9, 2022 Posted February 9, 2022 The behavior you describe of the trailer starting out very low quality is exactly what you will see in bandwidth constrained situations. YouTube will automatically reduce the quality to try to make the video play smoothly.
fallenwitch3r 45 Posted February 9, 2022 Author Posted February 9, 2022 but every other app work fine. Its just the emby app for android TV that have this low quality and flickering problem
ebr 16337 Posted February 9, 2022 Posted February 9, 2022 If you sideload this app on the same TV and play the same trailer, does it behave differently?
fallenwitch3r 45 Posted February 9, 2022 Author Posted February 9, 2022 can you explain what is the difference between the sideloaded app and the app i get from google play?
ebr 16337 Posted February 9, 2022 Posted February 9, 2022 The sideloaded one is our standard Android app that we are working on making compatible with TV devices as well (it is almost there). 1
fallenwitch3r 45 Posted February 9, 2022 Author Posted February 9, 2022 (edited) i`m a beta tester for the emby app. Is this beta not the latest? Is this the source for the sideload app your talking about? https://emby.media/emby-for-android-tv.html Edited February 9, 2022 by fallenwitch3r
ebr 16337 Posted February 9, 2022 Posted February 9, 2022 15 minutes ago, fallenwitch3r said: Is this the source for the sideload app your talking about? https://emby.media/emby-for-android-tv.html No, the APK can be found at the link I provided above.
fallenwitch3r 45 Posted February 10, 2022 Author Posted February 10, 2022 (edited) 9 hours ago, ebr said: The sideloaded one is our standard Android app that we are working on making compatible with TV devices as well (it is almost there). yes, same behavior and the ui is lagging like hell Edited February 10, 2022 by fallenwitch3r
ebr 16337 Posted February 10, 2022 Posted February 10, 2022 7 hours ago, fallenwitch3r said: and the ui is lagging like hell That kind of points in the direction of my conjecture about the TV not having a very good implementation of the technical component we use to display the YouTube videos. Have you checked for any firmware updates for the TV?
fallenwitch3r 45 Posted February 10, 2022 Author Posted February 10, 2022 No, there are no new updates until now. There will be android 11 this spring. Is it possible to make it more compatible for such TVs or is there any other way to play the trailers through the emby app?
