ruggy 2 Posted February 7, 2022 Posted February 7, 2022 Not sure if it's a new problem with 6.2.8 specifically but after I received the update, now whenever I delete a movie either from the Kodi emby menu or from the Emby app, my movie library in Kodi would lose a bunch of movies until I ask the plus in to repair the library.
quickmic 1709 Posted February 7, 2022 Posted February 7, 2022 (edited) Please send me a kodi log were you just delete one movie and wait till others are deleted. Edited February 7, 2022 by quickmic
ruggy 2 Posted February 7, 2022 Author Posted February 7, 2022 (edited) 9 hours ago, quickmic said: Please send me a kodi log were you just delete one movie and wait till others are deleted. How do I obtain a log? I tried going to emby next-gen's advanced settings and there's no option to turn on for logging. This is on ShieldTV btw if that makes a difference. Edited February 7, 2022 by ruggy
quickmic 1709 Posted February 7, 2022 Posted February 7, 2022 If you have no native file access -> https://kodi.wiki/view/Add-on:Kodi_Logfile_Uploader
ruggy 2 Posted February 7, 2022 Author Posted February 7, 2022 1 minute ago, quickmic said: If you have no native file access -> https://kodi.wiki/view/Add-on:Kodi_Logfile_Uploader So do you want to see the entire kodi debug log? I'm just following the instructions in this thread and I can't find the setting to enable logging for emby next-gen.
quickmic 1709 Posted February 7, 2022 Posted February 7, 2022 (edited) No, just the regular kodi.log. btw, the "how to report a problem" needs ans update. No valid for 5.x, 6.x versions Edited February 7, 2022 by quickmic
ruggy 2 Posted February 7, 2022 Author Posted February 7, 2022 Ok, I installed Kodi on my laptop and was able to reproduce the problem. kodi.log 1
quickmic 1709 Posted February 7, 2022 Posted February 7, 2022 ok, I think I see the problem. I'll try to fix in in next version. 1
quickmic 1709 Posted February 7, 2022 Posted February 7, 2022 Try this version: plugin.video.emby-next-gen-6.2.9-build 2 (fix remove items).zip
