Music Track Order Wrong?
Go to solution Solved by ScottIsAFool,
There are two ways to start a Music Album playing. One way plays the tracks in the correct order; the other doesn't.
If I display Albums, I can ( a ) tap alongside the album to open up the track list, select the tracks and start playing them or ( b ) tap on the Play icon on the Album cover art and the album tracks start playing automatically.
Here's an initial display of albums:
Let's tap alongside the Adele album to open up the track list (method ( a )):
This listing shows the tracks in the correct order. If I select them, and start playing them, they are also played in the correct order.
However, if I tap the Play icon on the Album cover (method ( b )), then the tracks seem to get shuffled, and the Now Playing list is in the wrong order:
I don't have shuffle selected, and all my music tracks have both the track number stored as an ID3.2 tag, and the track filename is prefixed with the track number in a 2-digit format.
Why does method ( b ) play the tracks in the incorrect order? Thanks.
  • 2 weeks later...
ScottIsAFool
Sounds like a bug, can you raise this on github if you haven't already done so. Thanks.
ScottIsAFool
Thanks.
  • 2 weeks later...
  • Solution
ScottIsAFool
This is fixed and will be in the next release (8.0.63.0)
  • Like 1
