flesan9974 0 Posted February 6, 2022 Posted February 6, 2022 Hi, I tried many times in vain to connect my Emby server to my Synology DS114 NAS Server. How can I solve this problem?
Luke 42243 Posted February 6, 2022 Posted February 6, 2022 Hi there, what exactly happens when you try to connect?
flesan9974 0 Posted February 6, 2022 Author Posted February 6, 2022 When I try to connect on the Emby application with the Synology folders, it simply doesn‘t accept the path I entered
Luke 42243 Posted February 7, 2022 Posted February 7, 2022 9 hours ago, flesan9974 said: When I try to connect on the Emby application with the Synology folders, it simply doesn‘t accept the path I entered Hi, what path are you trying to enter? Where are you trying to enter it?
flesan9974 0 Posted February 7, 2022 Author Posted February 7, 2022 I am entering in the Emby application the folder shared by Synology, but it doesn‘t accept it
Happy2Play 9812 Posted February 7, 2022 Posted February 7, 2022 1 hour ago, flesan9974 said: I am entering in the Emby application the folder shared by Synology, but it doesn‘t accept it Sound like you need to do this if I unstand correctly. 1
Carlo 4561 Posted February 7, 2022 Posted February 7, 2022 11 hours ago, flesan9974 said: I am entering in the Emby application the folder shared by Synology, but it doesn‘t accept it What I would do is forget about Emby to start with. What you want to do is use your file manager (File Explorer) on Windows to create a mount point. On Windows you could for example mount a drive Z: to your Synology media folder. This process allows you to use any username and password you have already setup on the Synology and given read/write access to. On Synology you will need to have Samba/CIFS and/or NFS setup and working of course to share files. Once you have a Z: drive mounted you just use that in Emby Server. If you're doing this on a Linux style OS you would do almost everything the same except you would create a new folder used to hold the mount point. You could for example create a mount point /mnt/media that is then used as the mount point. Once working you now just navigate to that location in Emby Server.
