xbmcgotham 35 Posted February 6, 2022 Posted February 6, 2022 Hi, any plans for a proper multi-zone audio sync output? In other words that you can play audio in one room, and than can quickly select other rooms that should play this same audio in sync. I know Squeezebox has this powerful feature but I like to keep it all in one application. Its something that is missing in many platforms, but a necessity for full house audio integration. 1
ebr 16339 Posted February 6, 2022 Posted February 6, 2022 Hi. This would be a sub-set of this (although even more complicated as syncing would be critical) and is discussed there:
