CFC 31 Posted February 6, 2022 Posted February 6, 2022 I've attached my logs. I've noticed that hardware transcoding is unable to work and the server falls back to software transcoding. I'm running a Docker container on a i5 Haswell series. Am I missing something obvious? Thanks for the help, CFC embyserver.txt ffmpeg-transcode-e08f9ec4-fe84-4788-b517-f03f4c6916ee_1.txt
Solution CFC 31 Posted February 7, 2022 Author Solution Posted February 7, 2022 I was able to sort this out. Though the server presents the QuickSync decoders/encoder as available, they don't work in Linux with a Haswell series processor. Got the hint from @softworkz's post here: As set up with VAAPI decoders/encoder it works correctly: CFC
