Fabio7586 0 Posted February 5, 2022 Posted February 5, 2022 Hello, i have a video with following info: General Unique ID : 57441334540874071546216562576913008607 (0x2B36CC729BB799E8308709BA783307DF) Complete name : \\nascasa\Multimedia\Film\Encanto Format : Matroska Format version : Version 4 File size : 16.1 GiB Duration : 1 h 42 min Overall bit rate : 22.6 Mb/s Encoded date : UTC 2021-12-25 20:28:46 Writing application : mkvmerge v63.0.0 ('Everything') 64-bit Writing library : libebml v1.4.2 + libmatroska v1.6.4 Cover : Yes Attachments : Encanto_cover.jpg Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5@Main Codec ID : V_MPEGH/ISO/HEVC Duration : 1 h 42 min Bit rate : 22.4 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.112 Stream size : 15.9 GiB (99%) Writing library : x265 3.5:[Linux][GCC 9.3.0][64 bit] 10bit Encoding settings : cpuid=1111039 / frame-threads=1 / numa-pools=16 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x2160 / interlace=0 / total-frames=0 / level-idc=50 / high-tier=0 / uhd-bd=0 / ref=3 / no-allow-non-conformance / repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / no-open-gop / min-keyint=48 / keyint=48 / gop-lookahead=0 / bframes=2 / b-adapt=1 / b-pyramid / bframe-bias=0 / rc-lookahead=48 / lookahead-slices=8 / scenecut=0 / hist-scenecut=0 / radl=0 / no-splice / no-intra-refresh / ctu=32 / min-cu-size=8 / no-rect / no-amp / max-tu-size=16 / tu-inter-depth=2 / tu-intra-depth=2 / limit-tu=0 / rdoq-level=1 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=3 / limit-refs=1 / no-limit-modes / me=1 / subme=2 / merange=44 / temporal-mvp / no-frame-dup / no-hme / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / no-sao / no-sao-non-deblock / rd=4 / selective-sao=0 / early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / b-intra / no-splitrd-skip / rdpenalty=1 / psy-rd=1.60 / psy-rdoq=5.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=abr / bitrate=23000 / qcomp=0.75 / qpstep=4 / stats-write=0 / stats-read=0 / vbv-maxrate=25000 / vbv-bufsize=25000 / vbv-init=0.9 / ipratio=1.40 / pbratio=1.30 / aq-mode=3 / aq-strength=1.00 / no-cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=0 / display-window=0 / cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.00 / hist-threshold=0.01 / no-opt-cu-delta-qp / no-aq-motion / no-hdr10 / hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / no-scenecut-aware-qpconformance-window-offsets / right=0 / bottom=0 Language : English Default : Yes Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Audio ID : 2 Format : E-AC-3 Format/Info : Enhanced AC-3 Commercial name : Dolby Digital Plus Codec ID : A_EAC3 Duration : 1 h 42 min Bit rate mode : Constant Bit rate : 256 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 187 MiB (1%) Language : Italian Service kind : Complete Main Default : Yes Forced : No Text #1 ID : 3 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 13 min 27 s Bit rate : 0 b/s Count of elements : 2 Stream size : 35.0 Bytes (0%) Title : Ita Forced Language : Italian Default : Yes Forced : Yes Text #2 ID : 4 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Duration : 1 h 40 min Bit rate : 50 b/s Count of elements : 1212 Stream size : 37.2 KiB (0%) Language : Italian Default : Yes Forced : No Menu 01:41:28.714 : en:Credits When i use emby color result is right part of attached image while with media player classic color are more lucent. Why? Can you solve?
Happy2Play 9811 Posted February 5, 2022 Posted February 5, 2022 Please post server and ffmpeg log for this example. Best guess transcoding/tone mapping.
Fabio7586 0 Posted February 5, 2022 Author Posted February 5, 2022 Here in attachmente Server log and ffmpeg transcode log. I hope that these are right files. Thank you for support embyserver.txt ffmpeg-transcode-7c0c6c2e-e25f-4380-ac75-2199f2e94d47_1.txt
Happy2Play 9811 Posted February 5, 2022 Posted February 5, 2022 Do you have Emby Premiere? Do you have the option enabled? Info Tone Mapping would be desired, but software tone mapping is disabled
Fabio7586 0 Posted February 5, 2022 Author Posted February 5, 2022 No, i dont. Why does i need a subscription to watch video in a correct way if this product is free?
Happy2Play 9811 Posted February 5, 2022 Posted February 5, 2022 2 minutes ago, Fabio7586 said: No, i dont. Why does i need a subscription to watch video in a correct way if this product is free? Devs may comment more.
Fabio7586 0 Posted February 5, 2022 Author Posted February 5, 2022 I already seen this option because i was saiyng as above; if product is free, why does for this option there is need a subscription? In this way i will check for another product, sorry
Luke 42240 Posted February 6, 2022 Posted February 6, 2022 We work very hard on Emby and we thank you for your support.
Fabio7586 0 Posted February 6, 2022 Author Posted February 6, 2022 6 hours ago, Luke said: We work very hard on Emby and we thank you for your support. And this what mean? I know you work very hard but This not answer my question...
