Bill LeDuc 5 Posted February 4, 2022 Posted February 4, 2022 Can you tell me why post processing is failing? See log clip below. Also, if i change containers to mkv and delete the ts file. will everything function as usual? 022-02-04 17:32:00.263 Info LiveTV: Running recording post processor EmbyPP.sh "/Volumes/SeaExt-3GB/Emby Recordings/Diners, Drive-Ins and Dives (2006)/Season 21/Diners, Drive-Ins and Dives S21E10 All Baltimore, All the Time.ts" 2022-02-04 17:32:00.268 Error LiveTV: Error running recording post processor *** Error Report *** Version: 4.6.7.0 Command line: /Applications/EmbyServer.app/Contents/MacOS/EmbyServer.dll Operating system: Darwin 21.2.0 Darwin Kernel Version 21.2.0: Sun Nov 28 20:29:10 PST 2021; root:xnu-8019.61.5~1/RELEASE_ARM64_T8101 Framework: .NET Core 3.1.8 OS/Process: x64/x64 Runtime: Applications/EmbyServer.app/Contents/MacOS/System.Private.CoreLib.dll Processor count: 8 Data path: /Users/williamleduc/.config/emby-server Application path: /Applications/EmbyServer.app/Contents/MacOS System.ComponentModel.Win32Exception: System.ComponentModel.Win32Exception (2): No such file or directory at System.Diagnostics.Process.ForkAndExecProcess(String filename, String[] argv, String[] envp, String cwd, Boolean redirectStdin, Boolean redirectStdout, Boolean redirectStderr, Boolean setCredentials, UInt32 userId, UInt32 groupId, UInt32[] groups, Int32& stdinFd, Int32& stdoutFd, Int32& stderrFd, Boolean usesTerminal, Boolean throwOnNoExec) at System.Diagnostics.Process.StartCore(ProcessStartInfo startInfo) at Emby.Server.Implementations.Diagnostics.CommonProcess.Start() at Emby.LiveTV.EmbyTV.PostProcessRecording(TimerInfo timer, String path) Source: System.Diagnostics.Process TargetSite: Boolean ForkAndExecProcess(System.String, System.String[], System.String[], System.String, Boolean, Boolean, Boolean, Boolean, UInt32, UInt32, UInt32[], Int32 ByRef, Int32 ByRef, Int32 ByRef, Boolean, Boolean)
Luke 42239 Posted February 5, 2022 Posted February 5, 2022 Hi, best guess is whatever file you setup as the post processor doesn't actually exist, or emby server doesn't have permissions to execute it.
