kaledi 42 Posted February 3, 2022 Posted February 3, 2022 Hello, A couple of issues / bugs I'd like to understand whether they are known or just with my system 1. Using Shield TV pro (2019) to play my movies. I've noticed that when playing 4K video, playing embeded subtitles, some types of subtitles cause video to skip frames / judder periodically. 2. Video re-encoded in Handbrake using DD+ as an audio encoder doesn't play any sound through EMBY. The same audio encoded as DD plays fine. Also confirmed the DD+ audio is encoded correctly as it plays fine via Plex.
ebr 16337 Posted February 4, 2022 Posted February 4, 2022 1 - Are these PGS subs? 2 - Can you please play that item for a few seconds and then follow the instructions to send a log from the app?
kaledi 42 Posted February 4, 2022 Author Posted February 4, 2022 For 2. I've played a clip and sent logs. For 1. Yes, but I think also DVDSUB.
ebr 16337 Posted February 5, 2022 Posted February 5, 2022 3 hours ago, kaledi said: I've played a clip and sent logs Quote Then add the following information to your report in the forum: Exactly what you were doing and what happened. Include the name of whatever you played if it is a playback problem The time you sent the log (in Eastern Time please - UTC -5) The name of the Emby user on the local server that was logged in at the time
