FredKing 0 Posted February 3, 2022 Posted February 3, 2022 Hi, I've recently started having trouble using the live TV guide with a remote control down arrow. Error 1 is that sometimes the channel loses the green highlight and then skips several channels. I can go up through the channels again and the next time it doesn't skip any channels. Error 2 is that sometimes the channel identifier will not go any further down past a particular channel. I can move it up again but if I try to go down it still won't go past the same channel. Error 2 is normally cleared by exiting the guide and starting again but this does not seem to help with error 1. Error 1 always skips the same channels. Any thoughts greatly appreciated.
justinrh 266 Posted February 4, 2022 Posted February 4, 2022 I've reported the same kind of issues just using the cursor keys on the web app guide. Thank you for reporting also!
FredKing 0 Posted February 5, 2022 Author Posted February 5, 2022 Hi - it's running on Emby Theater 1.1.400.0
Luke 42239 Posted February 8, 2022 Posted February 8, 2022 On 2/3/2022 at 4:31 PM, FredKing said: Hi, I've recently started having trouble using the live TV guide with a remote control down arrow. Error 1 is that sometimes the channel loses the green highlight and then skips several channels. I can go up through the channels again and the next time it doesn't skip any channels. Error 2 is that sometimes the channel identifier will not go any further down past a particular channel. I can move it up again but if I try to go down it still won't go past the same channel. Error 2 is normally cleared by exiting the guide and starting again but this does not seem to help with error 1. Error 1 always skips the same channels. Any thoughts greatly appreciated. HI, what are the steps to get this to occur? Thanks.
FredKing 0 Posted February 8, 2022 Author Posted February 8, 2022 Hi - all I do is open the guide and start to scroll down using cursor keys or down arrow on remote. Error 1 always occurs at the same channels and skips to the same channels, whereas error 2 appears much more randomly.
Luke 42239 Posted February 15, 2022 Posted February 15, 2022 Are you scrolling down with channels highlighted or programs?
FredKing 0 Posted February 15, 2022 Author Posted February 15, 2022 In fact it skips whichever I have highlighted. If programmes are highlighted before the jump, it reverts to channels being highlighted after the jump. In both cases the highlight disappears when a certain channel is reached and then the channels are skipped.
Luke 42239 Posted March 1, 2022 Posted March 1, 2022 OK we'll take a look at it. Thanks for reporting.
