wbravin 3 Posted February 3, 2022 Posted February 3, 2022 Hello all i have been using the benefits of emby for a number of years with no issues. Recently, kodi released ver 19 with many issues, and i had to revert back to 18.XX to continue to further develop and re configure all my music playlists that i lost during a major system issue. during one of the rebuilds i deleted the emby server located on my truenass box. Now that all is "almost" in order, I reinstalled the emby server in the truenas jail and restarted it. I mounted my media in truenass (tv shows, movies and music)is mounted the same way (media/music or movies or tv shows) in truenass jail. All my music has been processed via musicbraisn software. It has all the details )artist composer album cover etc. In emby server i added the media folder the same way /media/xxxx when i go to the home screen on the emby server and i go to music, i can see all my music folder and songs. however i do not see the album artist or the composer. further more not all the thumbnails are showing what am i missing
Luke 42237 Posted February 3, 2022 Posted February 3, 2022 @wbravin hi there, are your songs tagged with album artist values?
Happy2Play 9811 Posted February 4, 2022 Posted February 4, 2022 Can you also post a server log. If everything was process with "musicbrainz software" then the tags should be there assuming there is no tagging conflicts or multiple tags.
wbravin 3 Posted February 4, 2022 Author Posted February 4, 2022 22 hours ago, Luke said: @wbravin hi there, are your songs tagged with album artist values? hello thank you for replying so quickly. Yes. I run all my music through in musicbrains (because not all cd that i have or albums have all the information and i would add t5he missing information manually in the appropriate feild. If i load the library in kodi directly i get all the information. In addition prior to my issues all worked perfectly . Freenas media did not change structure
wbravin 3 Posted February 4, 2022 Author Posted February 4, 2022 Hello all here are what i feel are the most appropriate logs. Thank you for helping embyserver-63779491936.txt embyserver-63779386999.txt embyserver-63779381584.txt
Happy2Play 9811 Posted February 4, 2022 Posted February 4, 2022 Devs or fellow platform user will have to comment more but there is something wrong with ffmpeg/ffprobe as Emby cannot probe media to get the information. And looks like a path issue with SMB System.IO.FileNotFoundException: System.IO.FileNotFoundException: File not found. File name: 'smb://192.168.1.104/music/Elvis Presley/ELV1S- 30 '
wbravin 3 Posted February 4, 2022 Author Posted February 4, 2022 3 hours ago, Happy2Play said: Devs or fellow platform user will have to comment more but there is something wrong with ffmpeg/ffprobe as Emby cannot probe media to get the information. And looks like a path issue with SMB System.IO.FileNotFoundException: System.IO.FileNotFoundException: File not found. File name: 'smb://192.168.1.104/music/Elvis Presley/ELV1S- 30 ' Thank you for your reply. I saw that too. do i need to re-install and re configure emby server on truenas or/and the emby addon in kodi (more likely) and at that point re install kodi.? or should i just wait for an additional reply from someone else again thank you
Happy2Play 9811 Posted February 4, 2022 Posted February 4, 2022 1 minute ago, wbravin said: or should i just wait for an additional reply from someone else I would wait but believe there is a secondary step to getting Emby ffpmeg/ffprobe. Will look around for other topics on this.
Happy2Play 9811 Posted February 4, 2022 Posted February 4, 2022 Looking at this topic (same errors) you should be able to install beta 4.7.
Luke 42237 Posted February 5, 2022 Posted February 5, 2022 Hi, instead of adding smb libraries to Emby, try instead mounting them to a local path using the tools in the OS, and then setup the library with the local path instead. Please see if that helps. Thanks.
wbravin 3 Posted February 15, 2022 Author Posted February 15, 2022 hello all thank you for the suggestion and help just as an update I migrated to kodi 19.3 and emby next gen on my test pc, all videos (movies tv shows and youtube video) have loaded completely and correctly.... yuppie although the music library still is not loaded into kodi on the truenas all permissions are identical and have never changed for the last 13 years in trunas emby plugin,all libraries are mounted exactly in the same way In the emby dashboard: under library I deleted the music library added the music library again as /media/music/ rescanned the library restarted emby server. Now if i go to Home in the emby server dashboard, and select music. I do have files in "suggestions" nothing in "album artists" nothing under "composers" In "playlist i do have collection by artist (but no content under the playlist), this my be an different problem and i need to investigate on my end (I do not use these playlist. I normally go to kodi advance user settings and have the playlists i create play from there in "songs" all the library seems to be there and i manage to play a few under folders I seem to have all of them and i can play the songs in the subfolder of the artist On my trunas my music is sorted as follows (when i ha kodi 17 and with the emby addon before all worked fine and flawless and as said before all the music get processed by music brains to ensure correct data is assigned to the album and artist) in the emby for kodi addon setting i tried to repair the music library, delete the library and re added the music library /media/music/artist/album/tracks in kodi all libraries are mapped to a local "mapped drive" in my windows explorer. I see 2 issues a) emby server not mapping the music library to the proper dashboard filters b) emby next gen is not adding the music libraries to the kodi dash boar or to the i know not what else i can do thank you for your patience and help
Luke 42237 Posted February 15, 2022 Posted February 15, 2022 How are your libraries setup in Emby library setup? What folder paths did you use?
wbravin 3 Posted February 15, 2022 Author Posted February 15, 2022 (edited) thank you for your quick reply the following is my mounted folder in the truenas emby jail (under mount points) Music /mnt/media/iocage/jails/emby/root/media/music movies /mnt/media/iocage/jails/emby/root/media/movies tv shows /mnt/media/iocage/jails/emby/root/media/tv shows in the emby server library, the libraries are set up as follows: music /media/music movies /media/movies tv shows /media/tv shows Edited February 15, 2022 by wbravin
wbravin 3 Posted February 16, 2022 Author Posted February 16, 2022 hello all sorry to display my ignorance to add further confusion in emby server, running on truenas after adding the library (with no issues) i tried to play (always from the server) a file from movies or tv shows i get a playback error " no compatible streams are currently available" yet all files are shown I did verify the permission in truenas for each dataset and they include emby and myself with full control. I sign in either as myself as a user on emby server or as user emby. I get same result i hear this my be a ffmpeg issue I include here below a\ copy of the log Thank you ffmpeg-transcode-cc90825d-6262-40bd-b9d2-c42c86287cec_1.txt
Luke 42237 Posted February 16, 2022 Posted February 16, 2022 3 hours ago, wbravin said: hello all sorry to display my ignorance to add further confusion in emby server, running on truenas after adding the library (with no issues) i tried to play (always from the server) a file from movies or tv shows i get a playback error " no compatible streams are currently available" yet all files are shown I did verify the permission in truenas for each dataset and they include emby and myself with full control. I sign in either as myself as a user on emby server or as user emby. I get same result i hear this my be a ffmpeg issue I include here below a\ copy of the log Thank you ffmpeg-transcode-cc90825d-6262-40bd-b9d2-c42c86287cec_1.txt 2 kB · 0 downloads Can you please attach the emby server log as well? Thanks.
wbravin 3 Posted February 16, 2022 Author Posted February 16, 2022 7 minutes ago, Luke said: Can you please attach the emby server log as well? Thanks. Thank you so much for responding and your availability. I inserted 2 server logs the first is before i tried to play a video the second is after agani tank you for your patience embyserver.txt embyserver-63780627447.txt
Happy2Play 9811 Posted February 16, 2022 Posted February 16, 2022 My guess is you do not have Emby's ffmpeg/ffprobe as ffmpeg/ffprobe appears to not work at all on this system.
wbravin 3 Posted February 16, 2022 Author Posted February 16, 2022 (edited) Thank you for responding. what should i do in this case? how do i fix this? the jail is on truenas and all Kodi clients are on with the emby nex gen addon are on windows 10 i performed a sfc/scannow on my windows 10 test unit and the scan did find errors. they were corrected and the pc rebooted went the emby server dashboard (from my laptop) and tried to play from the server a movie. I got the same error also i used my home assistant laptop to login to emby server from that machine and proceeded to try this process again with the same result. therefore iMHO i feel that the error stems from the turenas server Correct? thank you again Edited February 16, 2022 by wbravin
wbravin 3 Posted February 17, 2022 Author Posted February 17, 2022 hello all today i uninstalled the emby plugin and jail from truenas i deleted the emby next gen addon from kodi i uninstalled kodi i rebooted truenass i installed emby server from the trunas community plugin list after basic configuration i mounted the libraries (as mentioned above) i opened the emby dashboard after basic configuration i added the libraries to emby (again as above) after the libraries were loaded i went to home and saw that all 3 libraries had content. However i could not play any video i get a playback error No compatible streams are currently available for both movies and tv shows under the music library under album artist, composers in playlist i see one album i shows songs i try to play then and i get a playback error. however under "songs" i see tracks and i can play some of them and others i get playback error. These songs are mp3 format and have been passed through music brains. and under folders i see all 660 folder and if i click on one of them i see the tracks. i can play some tracks and some others i get the playback error. I install kodi 19.3 on my windows 10 pc. I configured it as i needed. then i installed the emby next gen addon. I loaded all the video libraries with no errors. while in kodi I can play and hear the videos ( tried 5 movies and 5 tv shows) and it worked. emby addon did not load any of the music in kodi . even if i go to my addon sin kofdi and open up the emby addon and select music when i peruse the subfolders i find that they are all emby I include the hardware detection logs and the 2 server logs from when i reinstall all and finally the embyserver(1) which is the latest one. Between these server logs there many ffmeg logs. I hoe this helps thank you for for taking the time you are dedicating to this, your patience and help embyserver (1).txt embyserver-63780684674.txt embyserver-63780684735.txt hardware_detection-63780692384.txt
Luke 42237 Posted February 17, 2022 Posted February 17, 2022 When you tried to play, were any ffmpeg log files generated?
wbravin 3 Posted February 18, 2022 Author Posted February 18, 2022 8 hours ago, Happy2Play said: Have a look here Hello all, I'm running ver 4.6.7.0 of emby server . in reading the above message i see that this was happening in 4.6,4.0 would this still apply to me. if ermby ships it's own ffmpeg (and it says that in the next release this should be fixed does this still apply to my sittuation?
Happy2Play 9811 Posted February 18, 2022 Posted February 18, 2022 I honestly don't know but there are several topics on the wrong ffmpeg being use on this platform. But looking at the path being used would suggest to me that your are not using Emby's versions. I know there are major changes in beta 4.7 in this area. I know nothing of this platform but would assume you could copy/move Emby's ffmpeg/ffprobe to the folders being used per the linked topic.
wbravin 3 Posted February 18, 2022 Author Posted February 18, 2022 2 minutes ago, Happy2Play said: I honestly don't know but there are several topics on the wrong ffmpeg being use on this platform. But looking at the path being used would suggest to me that your are not using Emby's versions. I know there are major changes in beta 4.7 in this area. I know nothing of this platform but would assume you could copy/move Emby's ffmpeg/ffprobe to the folders being used per the linked topic. Thank you so much for taking the time to respond so late. i do not know what you mean by "copy/move emby's ffmep/ffprobe to the folders used per the linked above" do you mean go to the shell in truenas then go to /usr/local/etc and copy and paste all the code where it's highlighted /rc.d/emby-server or /usr/local/lib/emby-server/bin/ffmpeg" i'm not well versed in this (not at all to be sure ) and unfortunately i would rather wait for 4.7 and hope this would be fixed. I also run Plex (which i do not like) to insure that my setting (truenas settings ACL and paths) are correct. I my mind if it works in plex then truenas config is fine
Happy2Play 9811 Posted February 18, 2022 Posted February 18, 2022 31 minutes ago, wbravin said: Thank you so much for taking the time to respond so late. i do not know what you mean by "copy/move emby's ffmep/ffprobe to the folders used per the linked above" do you mean go to the shell in truenas then go to /usr/local/etc and copy and paste all the code where it's highlighted /rc.d/emby-server or /usr/local/lib/emby-server/bin/ffmpeg" i'm not well versed in this (not at all to be sure ) and unfortunately i would rather wait for 4.7 and hope this would be fixed. I also run Plex (which i do not like) to insure that my setting (truenas settings ACL and paths) are correct. I my mind if it works in plex then truenas config is fine I was just thinking copy or move ffmpeg/ffmprobe from /usr/local/lib/emby-server/bin to /usr/local/bin. As I believe these are none Emby versions. "freebsd -ffmpeg /usr/local/bin/ffmpeg -ffprobe /usr/local/bin/ffprobe" But I guess if the original paths can be reapplied it should work also, but know nothing about this platform.
