FrostByte 5453 Posted February 21, 2022 Posted February 21, 2022 If you want to consider Synology all their current 4-bay NAS devices are compatible with Emby Product List | Synology Inc. However, if you want to use hardware assisted transcoding you will need to stick with the plus models
Hispanico957 23 Posted February 22, 2022 Author Posted February 22, 2022 (edited) 1 hour ago, FrostByte said: If you want to consider Synology all their current 4-bay NAS devices are compatible with Emby Product List | Synology Inc. However, if you want to use hardware assisted transcoding you will need to stick with the plus models Thank FrostByte for your suggestions i thinking to this QNap (no too expensive): https://www.qnap.com/it-it/product/ts-451+/specs/hardware or https://www.qnap.com/it-it/product/ts-451d2/specs/hardware in specification i read 64-bit x86 ...so is compatible with Emby ? or... change brand and go to https://www.synology.com/en-us/products/DS420j (for this model of synology the emby version would be this: ARMv8 (x18 Series) ? (sry for request but i dont know Synology brand) Thank again Hispa Edited February 22, 2022 by Hispanico957
