Hispanico957 23 Posted February 2, 2022 Posted February 2, 2022 (edited) Hello I have installed on my QNAP TS-439 Pro II (4.2.6 firmware), the latest release of Intel / AMD 64 bit, everything ok but when I open it it gives me connection error at the nas address: 192.168.0.XX8096 ...ERR_CONNECTION_REFUSED Port 8096 is open on my router tcp/udp Thank Hispa Edited February 2, 2022 by Hispanico957
Happy2Play 9811 Posted February 4, 2022 Posted February 4, 2022 This usually means the connections is not considered local. Can you post a server log.
Hispanico957 23 Posted February 4, 2022 Author Posted February 4, 2022 10 hours ago, Happy2Play said: This usually means the connections is not considered local. Can you post a server log. This ? Hispa NBU8A0800665C.zip
Hispanico957 23 Posted February 5, 2022 Author Posted February 5, 2022 PLS no suggestions ?? Thank Hispa
Hispanico957 23 Posted February 5, 2022 Author Posted February 5, 2022 11 minutes ago, Happy2Play said: Can you post the Emby Server log, I post in the previous post or is not correct. So in which way i can see and load Emby server log ? Thank again Hispa
Happy2Play 9811 Posted February 5, 2022 Posted February 5, 2022 1 minute ago, Hispanico957 said: I post in the previous post or is not correct. So in which way i can see and load Emby server log ? Thank again Hispa Do not know the platform but I would assume you have to ssh to Emby logs folder. Have no idea what you posted above but assume is has to the with the NAS.
Hispanico957 23 Posted February 5, 2022 Author Posted February 5, 2022 (edited) So i verify win WinScp on entire nas and no log of emby server..these are entries: /etc/init.d/emby-server.sh /proc/self/task/14144/cwd/.BitTornado/emby-server.pid /proc/5978/task/5978/cwd/RSS/images/EmbyServer.gif /proc/5978/task/5978/cwd/RSS/images/EmbyServer_80.gif /proc/5978/task/5978/cwd/RSS/images/EmbyServer_gray.gif /share/MD0_DATA/.qpkg/EmbyServer/emby-server.sh /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.Ffmpeg.Lib.dll /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.Server.Connect.dll /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/livetvsetup/embydata.js /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/livetvsetup/embydata.html /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/userdatabuttons/emby-playstatebutton.js /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/userdatabuttons/emby-ratingbutton.js /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-checkbox/emby-checkbox.css /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-checkbox/emby-checkbox.js /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-progressring/emby-progressring.css /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-progressring/emby-progressring.js /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-progressring/emby-progressring.template.html /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-itemrefreshindicator/emby-itemrefreshindicator.js /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-collapse/emby-collapse.js /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-collapse/emby-collapse.css /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-slider/emby-slider.css /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-slider/emby-slider.js /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-scrollbuttons/emby-scrollbuttons.css /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-scrollbuttons/emby-scrollbuttons.js /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-input/emby-input.css /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-input/emby-input.js /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/sync/emby-downloadbutton.js /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-tabs/emby-tabs.css /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-tabs/emby-tabs.js /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-progressbar/emby-progressbar.js /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-progressbar/emby-progressbar.css /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-textarea/emby-textarea.js /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-textarea/emby-textarea.css /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-radio/emby-radio.css /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-radio/emby-radio.js /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-toggle/emby-toggle.css /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-toggle/emby-toggle.js /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-itemscontainer/emby-itemscontainer.js /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-select/emby-select.css /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-select/emby-select.js /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-button/emby-button.css /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-button/emby-button.js /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-scroller/emby-scroller.js /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/embypremiere/embypremiere.html /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/embypremiere/embypremiere.js /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.Web.dll /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.Notifications.dll /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.Server.MediaEncoding.dll /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.Codecs.Dxva.dll /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.Web.GenericEdit.dll /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.Media.Model.dll /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.Drawing.Skia.dll /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.Server.Implementations.dll /share/MD0_DATA/.qpkg/EmbyServer/system/plugins/Emby.Dlna.dll /share/MD0_DATA/.qpkg/EmbyServer/system/plugins/Emby.Webhooks.dll /share/MD0_DATA/.qpkg/EmbyServer/system/plugins/Emby.PortMapper.dll /share/MD0_DATA/.qpkg/EmbyServer/system/plugins/Emby.Server.CinemaMode.dll /share/MD0_DATA/.qpkg/EmbyServer/system/EmbyServer.deps.json /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.Codecs.dll /share/MD0_DATA/.qpkg/EmbyServer/system/EmbyServer.runtimeconfig.json /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.ActivityLog.dll /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.Ffmpeg.Base.dll /share/MD0_DATA/.qpkg/EmbyServer/system/EmbyServer /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.Sqlite.dll /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.Providers.dll /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.Photos.dll /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.ProcessRun.dll /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.Naming.dll /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.Ffmpeg.dll /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.Server.Sync.dll /share/MD0_DATA/.qpkg/EmbyServer/system/EmbyServer.dll /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.LocalMetadata.dll /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.Api.dll /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.LiveTV.dll /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.Drawing.dll /share/MD0_DATA/.qpkg/EmbyServer/bin/emby-ffdetect /share/MD0_DATA/.qpkg/EmbyServer/bin/emby-server /share/MD0_DATA/.qpkg/EmbyServer/bin/emby-ffmpeg Encolsed emby-server and emby-server.sh so you can verify Thank for your help Hispa emby-server emby-server.sh Edited February 5, 2022 by Hispanico957
Happy2Play 9811 Posted February 5, 2022 Posted February 5, 2022 But that would be Emby system folder not Emby data folder. From a log in another QNAP topic. Data path: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata Application path: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system
Hispanico957 23 Posted February 6, 2022 Author Posted February 6, 2022 (edited) 10 hours ago, Happy2Play said: But that would be Emby system folder not Emby data folder. From a log in another QNAP topic. Data path: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/programdata Application path: /share/CACHEDEV1_DATA/.qpkg/EmbyServer/system Sry but these path are not present on my QNap, llok and hidden file/folders are show and this is with search for *emby*: /etc/rcS.d/QS109EmbyServer /etc/init.d/emby-server.sh /etc/rcK.d/QK101EmbyServer /proc/self/task/15594/cwd/.BitTornado/emby-server.pid /proc/5977/task/5977/cwd/RSS/images/EmbyServer.gif /proc/5977/task/5977/cwd/RSS/images/EmbyServer_80.gif /proc/5977/task/5977/cwd/RSS/images/EmbyServer_gray.gif /share/MD0_DATA/.qpkg/EmbyServer/emby-server.sh /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.Ffmpeg.Lib.dll /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.Server.Connect.dll /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/livetvsetup/embydata.js /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/livetvsetup/embydata.html /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/userdatabuttons/emby-playstatebutton.js /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/userdatabuttons/emby-ratingbutton.js /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-checkbox/emby-checkbox.css /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-checkbox/emby-checkbox.js /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-progressring/emby-progressring.css /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-progressring/emby-progressring.js /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-progressring/emby-progressring.template.html /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-itemrefreshindicator/emby-itemrefreshindicator.js /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-collapse/emby-collapse.js /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-collapse/emby-collapse.css /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-slider/emby-slider.css /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-slider/emby-slider.js /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-scrollbuttons/emby-scrollbuttons.css /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-scrollbuttons/emby-scrollbuttons.js /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-input/emby-input.css /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-input/emby-input.js /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/sync/emby-downloadbutton.js /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-tabs/emby-tabs.css /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-tabs/emby-tabs.js /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-progressbar/emby-progressbar.js /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-progressbar/emby-progressbar.css /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-textarea/emby-textarea.js /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-textarea/emby-textarea.css /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-radio/emby-radio.css /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-radio/emby-radio.js /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-toggle/emby-toggle.css /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-toggle/emby-toggle.js /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-itemscontainer/emby-itemscontainer.js /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-select/emby-select.css /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-select/emby-select.js /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-button/emby-button.css /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-button/emby-button.js /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/modules/emby-elements/emby-scroller/emby-scroller.js /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/embypremiere/embypremiere.html /share/MD0_DATA/.qpkg/EmbyServer/system/dashboard-ui/embypremiere/embypremiere.js /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.Web.dll /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.Notifications.dll /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.Server.MediaEncoding.dll /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.Codecs.Dxva.dll /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.Web.GenericEdit.dll /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.Media.Model.dll /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.Drawing.Skia.dll /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.Server.Implementations.dll /share/MD0_DATA/.qpkg/EmbyServer/system/plugins/Emby.Dlna.dll /share/MD0_DATA/.qpkg/EmbyServer/system/plugins/Emby.Webhooks.dll /share/MD0_DATA/.qpkg/EmbyServer/system/plugins/Emby.PortMapper.dll /share/MD0_DATA/.qpkg/EmbyServer/system/plugins/Emby.Server.CinemaMode.dll /share/MD0_DATA/.qpkg/EmbyServer/system/EmbyServer.deps.json /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.Codecs.dll /share/MD0_DATA/.qpkg/EmbyServer/system/EmbyServer.runtimeconfig.json /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.ActivityLog.dll /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.Ffmpeg.Base.dll /share/MD0_DATA/.qpkg/EmbyServer/system/EmbyServer /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.Sqlite.dll /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.Providers.dll /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.Photos.dll /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.ProcessRun.dll /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.Naming.dll /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.Ffmpeg.dll /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.Server.Sync.dll /share/MD0_DATA/.qpkg/EmbyServer/system/EmbyServer.dll /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.LocalMetadata.dll /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.Api.dll /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.LiveTV.dll /share/MD0_DATA/.qpkg/EmbyServer/system/Emby.Drawing.dll /share/MD0_DATA/.qpkg/EmbyServer/bin/emby-ffdetect /share/MD0_DATA/.qpkg/EmbyServer/bin/emby-server /share/MD0_DATA/.qpkg/EmbyServer/bin/emby-ffmpeg Hispa Edited February 6, 2022 by Hispanico957
Happy2Play 9811 Posted February 6, 2022 Posted February 6, 2022 So there is no /share/MD0_DATA/.qpkg/EmbyServer/programdata?
Hispanico957 23 Posted February 6, 2022 Author Posted February 6, 2022 (edited) 29 minutes ago, Happy2Play said: So there is no /share/MD0_DATA/.qpkg/EmbyServer/programdata? There is but is empty. I enclosed the content of /share/MD0_DATA/.qpkg/EmbyServer Hispa emby.txt Edited February 6, 2022 by Hispanico957
Hispanico957 23 Posted February 7, 2022 Author Posted February 7, 2022 Please give me a hand to solve I just don't know how to solve .... Thank Hispa
Hispanico957 23 Posted February 7, 2022 Author Posted February 7, 2022 (edited) I read in this old post similar problem: so where i can old release of emby to see in installing on my QNAP solve the problem ? Thank Hispa Edited February 7, 2022 by Hispanico957
Happy2Play 9811 Posted February 7, 2022 Posted February 7, 2022 4 minutes ago, Hispanico957 said: I rean in this old post similar problem: so where i can old release of emby to see in installing on my QNAP solev the problem ? Thank Hispa You will create more issues as downgrading would/could corrupt your current install as the database has changed over time and that topic is from almost 8 years ago so issues them are not the same issues now. But you can check GitHub for previous releases. Releases · MediaBrowser/Emby.Releases (github.com) 1
Hispanico957 23 Posted February 8, 2022 Author Posted February 8, 2022 In fact you're right it didn't work ... I do not understand, however, if something does not work in the installation and does not copy the necessary files or if there is something in the settings, as the server does not start ... Hispa
Hispanico957 23 Posted February 10, 2022 Author Posted February 10, 2022 Please help me solve this problem, I tried also old releases but nothing ... Thank Hispanico
Hispanico957 23 Posted February 12, 2022 Author Posted February 12, 2022 (edited) I see also this post But i dont understand how solve for my QNAP 439 PRO II Infact emby in my QNAP is installed in /share/MD0_DATA/.qpkg/EmbyServer/bin/emby-server and not in /share/CACHEDEV1_DATA/.qpkg/EmbyServer/bin/emby-server i try also to send this command /share/MD0_DATA/.qpkg/EmbyServer/bin/emby-server but receive: login as: admin admin@192.168.0.100's password: [~] # /share/MD0_DATA/.qpkg/EmbyServer/bin/emby-server -sh: /share/MD0_DATA/.qpkg/EmbyServer/bin/emby-server: No such file or directory [~] # /share/MD0_DATA/.qpkg/EmbyServer/bin/emby-server /share/MD0_DATA/.qpkg/EmbyServer/system/EmbyServer: error while loading shared l ibraries: libdl.so.2: wrong ELF class: ELFCLASS32 [~] # Hispanico Edited February 12, 2022 by Hispanico957
Hispanico957 23 Posted February 13, 2022 Author Posted February 13, 2022 But sry support my QNAP TS-439 Pro II (4.2.6 firmware) is supported from Emby or not or i must use an old version of Emby to run properly ? Thank Hispa
Hispanico957 23 Posted February 15, 2022 Author Posted February 15, 2022 Excuse me but what support and help you are giving me, I have posted all the information possible, I have read a lot about why Emby server on the QNAP TS-439 PRo II gives connection error, but apart from some minimal info I have not received any help on how to make it work . There is no point in releasing QNAP releases if they don't work. I hope someone has an interest in helping me Thank Hispa
Hispanico957 23 Posted February 16, 2022 Author Posted February 16, 2022 (edited) Just as information: Quote From alucryd All our qnap packages are configured with QTS_MINI_VERSION set to 4.1.0. Generally speaking if the firmware ships with glibc 2.17 (2.12.1 for armv5 CPUs) or newer it should work out of the box, if it doesn't we just ship our own glibc and in most (if not all) cases that is enough. Recent changes in our toolchains made it almost trivial to support even the very oldest armv5 models, so apart from the odd firmware here and there (for instance TS531P is giving us troubles for some reason I don't yet understand) I don't see anything preventing us from supporting the whole lineup yet. In terms of requirements, the x86_64 and aarch64 (dotnet-core based) and armv5 (mono-based) packages are pretty much universal, and the armv7 packages come in both dotnet core and mono variants, the former for CPUs with NEON support, the latter for CPUs without NEON support. So on my QNAP TS-439 PRO II and firmware 4.2.6...why Emby form last stable version but also from older 3.x versions give me this error and at this moment no solution or suggestions from team ? I think that my NAS is 32 bit so pheraps last release of Emby are not correct ? and if yes which release i can install ? Again thank Hispa Edited February 16, 2022 by Hispanico957
Hispanico957 23 Posted February 21, 2022 Author Posted February 21, 2022 PLS and goog morning... Someone can you help me to understand how FIX this issue on my QNap ? Thank a lot Hispaa
Luke 42241 Posted February 21, 2022 Posted February 21, 2022 Hi, this is a 32-bit 2010 device? We don't currently have a compatible package for this right now, sorry. 1
Hispanico957 23 Posted February 21, 2022 Author Posted February 21, 2022 (edited) 6 hours ago, Luke said: Hi, this is a 32-bit 2010 device? We don't currently have a compatible package for this right now, sorry. Arghhhh also with old release of Emby ? If not ....which QNAP 4 bay is compatible with emby ? (no too expensive) Thank Hispa Edited February 21, 2022 by Hispanico957
Luke 42241 Posted February 21, 2022 Posted February 21, 2022 54 minutes ago, Hispanico957 said: Arghhhh also with old release of Emby ? If not ....which QNAP 4 bay is compatible with emby ? (no too expensive) Thank Hispa hi, the ts-451+ is great. @FrostByte might also be able to suggest a Synology.
