Hispanico957 23 Posted February 2, 2022 Posted February 2, 2022 I have TV Samsung UE55ks7000 and last version of emby (https://github.com/MediaBrowser/Emby.Releases/raw/master/tizen/tizen.zip) All installation go well but when i go to insert address but this is impossible because when i search to go down, the cursor go in port. I only can write in address if i rest in first line of keyboard. I try to unistall app and reinstall but not solve. The remote is good infact in other app Amazon, netflix etc..i don have problem to write Thank fr your help Hispa
FrostByte 5453 Posted February 2, 2022 Posted February 2, 2022 Try the update Luke made in the link below. It fixed some of the remote-control issues with K series like back, etc 1
Hispanico957 23 Posted February 2, 2022 Author Posted February 2, 2022 Ok thank i try tomorrow...but with this release appear always that there is a update of emby when launch app ? Thank again mate Hispa
Luke 42241 Posted February 2, 2022 Posted February 2, 2022 27 minutes ago, Hispanico957 said: Ok thank i try tomorrow...but with this release appear always that there is a update of emby when launch app ? Thank again mate Hispa HI, what release are you referring to?
Hispanico957 23 Posted February 3, 2022 Author Posted February 3, 2022 7 hours ago, Luke said: HI, what release are you referring to? Thank ...your file upload 25 january Hispa
Hispanico957 23 Posted February 3, 2022 Author Posted February 3, 2022 Unfortunately i installed rhis version but always is impossible when insert address go down with key of remeote...always the cursor go to port Pls help me Thank Hispa
Hispanico957 23 Posted February 4, 2022 Author Posted February 4, 2022 So no solution for this bug ? Pls thank Hispa
Hispanico957 23 Posted February 6, 2022 Author Posted February 6, 2022 Pherasp with old version of emby for samsun (tizen) this problem not appear i remember this... after upgrade appear this BUG Some where are old version of emby for samsung ? i can try Thank Hispa
Luke 42241 Posted February 7, 2022 Posted February 7, 2022 Can you please try this version? Thanks.tizen.zip 1
Hispanico957 23 Posted February 7, 2022 Author Posted February 7, 2022 4 hours ago, Luke said: Can you please try this version? Thanks.tizen.zip Many thanks LUKE works perfectly! You have been very courteous and patient .... Gooood day Hispa 1
