Tester 45 Posted September 19, 2014 Posted September 19, 2014 I am starting to mess with DLNA but having all sorts of issues.. Since I am a newbie at it, I have to assume I am doing almost everything wrong. Having said that, before I start posting issues/questions, it sure would be nice to follow a DLNA startup guide to start with. Anyone ? 1
TheShanMan 41 Posted September 21, 2014 Posted September 21, 2014 Ditto. I've tried using mediabrowser on my 2 dlna clients and it doesn't work on either out of the box. One allows me to browse all content but gives a "file corrupt or missing" error when I try to play something and the other only shows top level folders which are empty if you try to navigate to them. I realize that I'll need to set up profiles for my devices but I wouldn't know how to go about it.
Happy2Play 9811 Posted September 22, 2014 Posted September 22, 2014 If you google "writing dlna profile" there is a pretty comprehensive guide, every dlna server is implemented differently. But your best bet is just to ask if you are having issues with a device or profile.
gcoupe 63 Posted September 22, 2014 Posted September 22, 2014 If you google "writing dlna profile" there is a pretty comprehensive guide, every dlna server is implemented differently. But your best bet is just to ask if you are having issues with a device or profile. Well, that's all very well, but I pointed out an issue with my Denon AVR back in April. It still hasn't been solved.
Tester 45 Posted September 22, 2014 Author Posted September 22, 2014 (edited) If you google "writing dlna profile" there is a pretty comprehensive guide, every dlna server is implemented differently. But your best bet is just to ask if you are having issues with a device or profile. I agree, but I still think there is enough to create an "MB3 side only" guide.. things like how/why User profiles are linked with DLNA profiles would be very helpful. Regardless, I went ahead and posted my first issue here Edited September 23, 2014 by Tester
Tester 45 Posted October 1, 2014 Author Posted October 1, 2014 Ok, no guide, no responses to my issue. How about suggestions as to where we can find general DLNA help ?
MediaExplorer 2 Posted October 4, 2014 Posted October 4, 2014 Setting up DLNA on any device is a trial and error process. If you are looking for help on a specific device you can always start a new topic assuming you have done a quick search on this forum. In general, you can copy the profiles given in MBS and modify those until you get it just right. Direct play and transcoding tabs are the usual starting point. Keep an eye on server logs and transcoding logs as you go along. This may not be the step-by-step guide you were looking for but I hope it gets you started on it.
