daedalus 434 Posted February 1, 2022 Posted February 1, 2022 (edited) is there a way to force software decoding? i run emby on a Sharp 40BN5EA (Android TV 9) with a stereo soundsystem connected by 3.5 mm jack, but problem is also on the build in speakers at first i had the release version 2.0.48g which pretty much always did software decode for the audio and all sounded normal then i switched to beta 2.0.64g for testing, cause i had some DV files not triggering the TV, beta fixed most DV files here, but now dolby 5.1 audio suddently sounded very thin, flat and tiny i noticed that on these files audio is now not software decoded anymore but plays "direct" (shown in stats for nerds), as shot in the dark, i tried the correct playback option and it switched to software decode for the audio and voila normal rich sound was back so there seems to be a problem on my TV to handle/downmix these files deliverd from emby, cause i don't noticed anything abnormal with tv stations using dolby 5.1 or eg the amazon app (but i dont know what it is doing, probably also software decode) audio settings on that TV itself are pretty limited, but however, i tried to flip them all with no effect on attempting to force emby to software decode by default again so is there a way to force software decoding? emby isn't showing any audio related settings here Edited February 20, 2022 by daedalus specified title
GrimReaper 4898 Posted February 1, 2022 Posted February 1, 2022 What AndroidTV client app Audio Out options under Settings>Playback tab you have listed/selected?
ebr 16337 Posted February 1, 2022 Posted February 1, 2022 27 minutes ago, GrimReaper said: What AndroidTV client app Audio Out options under Settings>Playback tab you have listed/selected? You probably don't have that option in the settings, huh...?
daedalus 434 Posted February 1, 2022 Author Posted February 1, 2022 1 minute ago, ebr said: You probably don't have that option in the settings, huh...? no
ebr 16337 Posted February 1, 2022 Posted February 1, 2022 Okay, yeah, with the change that was made in the last beta, I need to enable that for you so you can select "Mix down to stereo" if you want to. Thanks.
daedalus 434 Posted February 1, 2022 Author Posted February 1, 2022 2 minutes ago, ebr said: Okay, yeah, with the change that was made in the last beta, I need to enable that for you so you can select "Mix down to stereo" if you want to. Thanks. if that would force the software decode, so yes please
daedalus 434 Posted February 13, 2022 Author Posted February 13, 2022 as two weeks went by, any time frame for this?
daedalus 434 Posted February 20, 2022 Author Posted February 20, 2022 (edited) in latest beta setting is now exposed and working as expected but i recently stumbled across something else, what i first thought it's just how that tv/soundssystem work together, cause i didn't play any stereo files while volume for stereo files is normal, volume for 5.1+ files, even with forced downmix, is very low any chance to get a setting to boost volume together with the downmixing? Edited February 20, 2022 by daedalus
ebr 16337 Posted February 20, 2022 Posted February 20, 2022 So, this is not the case when you set it to downmix? On 2/1/2022 at 5:23 PM, daedalus said: i tried the correct playback option and it switched to software decode for the audio and voila normal rich sound was back The playback should be the same as when you did the playback correction technique.
daedalus 434 Posted February 20, 2022 Author Posted February 20, 2022 this was about the sound itself, volume was low before and is about the same when playing with or without the force downmix as said, i just didnt noticed that stereo files are noticeable louder than multi channel ones, cause i didn't played any until now
daedalus 434 Posted February 20, 2022 Author Posted February 20, 2022 just a throw in on the playback correction, just before the beta it suddently "stopped" working to just try software decode on the first attempt and directly jumped over to fully transcode everything, video and audio (that to aac 7.1)
