saffar4ever 0 Posted January 30, 2022 Posted January 30, 2022 Hi, Correct me if I am wrong, I don't see the subtitles options in the library options anymore. I have OpenSubtitles plugin installed. Is this a bug or a wrong setting I have? Regards, Meshaal
saffar4ever 0 Posted January 30, 2022 Author Posted January 30, 2022 Hi Luke, I went to the web app > Settings > Library > chose a library > Selected show advanced settings. I am pretty sure the settings were there, especially the option to choose which subtitle to automatically download.
GrimReaper 4896 Posted January 30, 2022 Posted January 30, 2022 Well, that's a strange one. Could you install some other sub plugin (Podnapisi, Addic7ed...) from plugin catalogue and see if same can be observed?
saffar4ever 0 Posted January 30, 2022 Author Posted January 30, 2022 I installed Addic7ed and still the same problem. By the way, on Android app, I can see the subtitles options. I can also see OpenSubtitles and Addic7ed both listed. I assume it is a problem with the web app only.
saffar4ever 0 Posted January 30, 2022 Author Posted January 30, 2022 Good idea. I just tried Firefox and for some unknown reason, I couldn't login. I don't use Firefox anyway. I also just tried Edge and I was able to login. Unfortunately, the same issue exists.
Luke 42241 Posted January 31, 2022 Posted January 31, 2022 Please attach the emby server log. Thanks.
saffar4ever 0 Posted January 31, 2022 Author Posted January 31, 2022 Please find the direct link to the server log here : https://drive.google.com/file/d/12ec7EUg9LbTbsLG2ckO2wsV0naB8sc5z/view?usp=sharing
Luke 42241 Posted February 4, 2022 Posted February 4, 2022 @saffar4ever are you still having an issue with this? If you use our hosted web app, do you see the options? http://app.emby.media
saffar4ever 0 Posted February 5, 2022 Author Posted February 5, 2022 Yes, I still have the issue. I always use the hosted web app to login. You have given me the idea to try the local instance. Surprisingly, I can see the options in the local instance! I guess the issue is with the hosted web app.
Luke 42241 Posted February 7, 2022 Posted February 7, 2022 OK that's strange. Can you try it again and see if they're visible now? Thanks.
