RUFOALVAREZ 0 Posted January 30, 2022 Posted January 30, 2022 Hola desde hace unos meses se cambia la IP EN EL HOGAR LAN, por lo tanto no puede conectar las tv al emby server....tengo que volver a introducir la nueva ip. Antes no ocurria, me puede decir al guiemn por que? Un saludo.
Abobader 3485 Posted January 30, 2022 Posted January 30, 2022 Hello RUFOALVAREZ, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
rodainas 191 Posted January 30, 2022 Posted January 30, 2022 Asignale una ip fija al servidor ingresando a la configuracion del router y listo.
Luke 42186 Posted January 31, 2022 Posted January 31, 2022 Hi @RUFOALVAREZ I would suggest checking out our connection troubleshooter: https://support.emby.media/support/solutions/articles/44001849007-connectivity please try the steps listed there and let us know which ones succeed and which ones do not. Thanks !
RUFOALVAREZ 0 Posted February 2, 2022 Author Posted February 2, 2022 Lucas, lo que sugiere el articulo esta bien y lo he comprobado, pero sigue el problema porque el servidor emby, cada ciertos días cambia la IP local, por lo cual las TVs de casa enlazadas por cable de red, no encuentran la IP y no pueden conectarse... @cayars
Carlo 4561 Posted February 2, 2022 Posted February 2, 2022 If your media server is changing IPs inside your LAN that's an easy fix. What you want to do is go into your router and setup a reserved IP address. Normally this is done by assigning an IP address to the MAC address of the LAN card in the server. You can watch this Youtube video for an idea how to do this:
