DavidDK 2 Posted January 30, 2022 Posted January 30, 2022 So I have docker installed on my Synology NAS. Before, I was using Plex native on Synology. So I'm new to Emby and new to docker. I have an Emby container with some mapped volumes to the media folders on my NAS. Screenshot of my docker setup included. Then I made 3 libraries in Emby pointing toward those mapped volumes (screenshot also included). Unfortunately, my libraries remain empty. So setup looks like this: On my NAS I have a media folder with all my media files seperated into 3 different subfolders: /volume1/media/movies /volume1/media/music /volume1/media/tvshows I have a docker container wit these folder mapped as follows: /volume1/media/movies:/mnt/movies /volume1/media/music:/mnt/music /volume1/media/tvshows:/mnt/tvshows I made sure the "emby" user on my NAS has permission to the /volume1/media folder as well as the /volume1/docker/emby folder. Though in de logging created while scanning library files I found an "UnauthorizedAccessException". First question is, is this about folder permissions or is there a problem with how I mapped the docker volumes? And the second of course, how to fix this. 2022-01-30 12:04:52.726 Info Server: http/1.1 POST http://192.168.0.5:8096/emby/Items/f137a2dd21bbc1b99aa5c0f6bf02a805/Refresh?Recursive=true&ImageRefreshMode=Default&MetadataRefreshMode=Default&ReplaceAllImages=false&ReplaceAllMetadata=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Safari&X-Emby-Device-Id=cfe411d5-eca2-43a3-a7f4-a598919e25fb&X-Emby-Client-Version=4.6.7.0. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/15.2 Safari/605.1.15 2022-01-30 12:04:52.738 Info Server: http/1.1 Response 204 to 172.17.0.1. Time: 12ms. http://192.168.0.5:8096/emby/Items/f137a2dd21bbc1b99aa5c0f6bf02a805/Refresh?Recursive=true&ImageRefreshMode=Default&MetadataRefreshMode=Default&ReplaceAllImages=false&ReplaceAllMetadata=false&X-Emby-Client=Emby Web&X-Emby-Device-Name=Safari&X-Emby-Device-Id=cfe411d5-eca2-43a3-a7f4-a598919e25fb&X-Emby-Client-Version=4.6.7.0 2022-01-30 12:04:52.798 Error App: Error validating images for /config/root/default/Movies *** Error Report *** Version: 4.6.7.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 4.4.180+ (root@build13) (gcc version 7.5.0 (GCC) ) #42218 SMP Mon Oct 18 19:16:55 CST 2021 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 4 Data path: /config Application path: /system System.UnauthorizedAccessException: System.UnauthorizedAccessException: Access to the path '/mnt/movies' is denied. ---> System.IO.IOException: Permission denied --- End of inner exception stack trace --- at System.IO.Enumeration.FileSystemEnumerator`1.CreateDirectoryHandle(String path, Boolean ignoreNotFound) at System.IO.Enumeration.FileSystemEnumerator`1.Init() at System.IO.Enumeration.FileSystemEnumerable`1..ctor(String directory, FindTransform transform, EnumerationOptions options, Boolean isNormalized) at System.IO.Enumeration.FileSystemEnumerableFactory.FileInfos(String directory, String expression, EnumerationOptions options, Boolean isNormalized) at System.IO.DirectoryInfo.InternalEnumerateInfos(String path, String searchPattern, SearchTarget searchTarget, EnumerationOptions options) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFiles(String path, String[] extensions, Boolean enableCaseSensitiveExtensions, Boolean recursive) at System.Linq.Enumerable.SelectManySingleSelectorIterator`2.ToArray() at System.Linq.Buffer`1..ctor(IEnumerable`1 source) at System.Linq.OrderedEnumerable`1.ToList() at MediaBrowser.LocalMetadata.Images.LocalImageProvider.GetImages(BaseItem item, LibraryOptions libraryOptions, IEnumerable`1 paths, Boolean arePathsInMediaFolders, IDirectoryService directoryService) at MediaBrowser.LocalMetadata.Images.CollectionFolderLocalImageProvider.GetImages(BaseItem item, LibraryOptions libraryOptions, IDirectoryService directoryService) at System.Linq.Enumerable.SelectManySingleSelectorIterator`2.ToList() at MediaBrowser.Providers.Manager.ItemImageProvider.ValidateImages(BaseItem item, LibraryOptions libraryOptions, IEnumerable`1 providers, IDirectoryService directoryService) at MediaBrowser.Providers.Manager.MetadataService`2.RefreshMetadata(BaseItem item, MetadataRefreshOptions refreshOptions, LibraryOptions libraryOptions, CancellationToken cancellationToken) Source: System.IO.FileSystem TargetSite: IntPtr CreateDirectoryHandle(System.String, Boolean) InnerException: System.IO.IOException: Permission denied Source: TargetSite: 2022-01-30 12:04:52.803 Error BaseItem: Error refreshing owned items for /mnt/movies *** Error Report *** Version: 4.6.7.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 4.4.180+ (root@build13) (gcc version 7.5.0 (GCC) ) #42218 SMP Mon Oct 18 19:16:55 CST 2021 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 4 Data path: /config Application path: /system System.UnauthorizedAccessException: System.UnauthorizedAccessException: Access to the path '/mnt/movies' is denied. ---> System.IO.IOException: Permission denied --- End of inner exception stack trace --- at System.IO.Enumeration.FileSystemEnumerator`1.CreateDirectoryHandle(String path, Boolean ignoreNotFound) at System.IO.Enumeration.FileSystemEnumerator`1.Init() at System.IO.Enumeration.FileSystemEnumerable`1..ctor(String directory, FindTransform transform, EnumerationOptions options, Boolean isNormalized) at System.IO.Enumeration.FileSystemEnumerableFactory.FileSystemInfos(String directory, String expression, EnumerationOptions options, Boolean isNormalized) at System.IO.DirectoryInfo.InternalEnumerateInfos(String path, String searchPattern, SearchTarget searchTarget, EnumerationOptions options) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.Controller.Entities.BaseItem.RefreshMetadata(MetadataRefreshOptions options, LibraryOptions libraryOptions, CancellationToken cancellationToken) Source: System.IO.FileSystem TargetSite: IntPtr CreateDirectoryHandle(System.String, Boolean) InnerException: System.IO.IOException: Permission denied Source: TargetSite: 2022-01-30 12:04:52.803 Error App: Error validating images for /mnt/movies *** Error Report *** Version: 4.6.7.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Linux version 4.4.180+ (root@build13) (gcc version 7.5.0 (GCC) ) #42218 SMP Mon Oct 18 19:16:55 CST 2021 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: system/System.Private.CoreLib.dll Processor count: 4 Data path: /config Application path: /system System.UnauthorizedAccessException: System.UnauthorizedAccessException: Access to the path '/mnt/movies' is denied. ---> System.IO.IOException: Permission denied --- End of inner exception stack trace --- at System.IO.Enumeration.FileSystemEnumerator`1.CreateDirectoryHandle(String path, Boolean ignoreNotFound) at System.IO.Enumeration.FileSystemEnumerator`1.Init() at System.IO.Enumeration.FileSystemEnumerable`1..ctor(String directory, FindTransform transform, EnumerationOptions options, Boolean isNormalized) at System.IO.Enumeration.FileSystemEnumerableFactory.FileSystemInfos(String directory, String expression, EnumerationOptions options, Boolean isNormalized) at System.IO.DirectoryInfo.InternalEnumerateInfos(String path, String searchPattern, SearchTarget searchTarget, EnumerationOptions options) at Emby.Server.Implementations.IO.ManagedFileSystem.GetFileSystemEntries(String path, Boolean recursive) at MediaBrowser.Controller.Providers.DirectoryService.GetFileSystemEntries(String path) at MediaBrowser.LocalMetadata.Images.LocalImageProvider.GetFiles(BaseItem item, LibraryOptions libraryOptions, Boolean includeDirectories, IDirectoryService directoryService) at MediaBrowser.LocalMetadata.Images.LocalImageProvider.GetImages(BaseItem item, LibraryOptions libraryOptions, IDirectoryService directoryService) at System.Linq.Enumerable.SelectManySingleSelectorIterator`2.ToList() at MediaBrowser.Providers.Manager.ItemImageProvider.ValidateImages(BaseItem item, LibraryOptions libraryOptions, IEnumerable`1 providers, IDirectoryService directoryService) at MediaBrowser.Providers.Manager.MetadataService`2.RefreshMetadata(BaseItem item, MetadataRefreshOptions refreshOptions, LibraryOptions libraryOptions, CancellationToken cancellationToken) Source: System.IO.FileSystem TargetSite: IntPtr CreateDirectoryHandle(System.String, Boolean) InnerException: System.IO.IOException: Permission denied Source: TargetSite: 2022-01-30 12:04:58.891 Info Server: http/1.1 GET http://192.168.0.5:8096/emby/System/Logs/embyserver.txt. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/15.2 Safari/605.1.15
Carlo 4561 Posted January 30, 2022 Posted January 30, 2022 Hi, for Synology there's no need to use docker for Emby as it makes the configuration and permissions much harder. I'd suggest downloading the current release right from out web site and installing it via package center. Then set read/write permissions for the system internal emby user on any shares that Emby will access. That should be all that's needed installing normally.
Luke 42243 Posted January 30, 2022 Posted January 30, 2022 Hi, to answer the original question, it looks like emby server is being denied access to read the contents of the folders. Please let us know if this helps. Thanks.
Solution DavidDK 2 Posted February 5, 2022 Author Solution Posted February 5, 2022 This topic can be closed. I made it work by giving the docker container full administrator rights on my NAS. That wasn't exactly the solution I was looking for though, so I decided to use the native Emby app for Synology instead of using Docker. Everything went fast 'n smooth after that. Thanks for the advise! 2
Carlo 4561 Posted February 5, 2022 Posted February 5, 2022 I was hoping you would do that. Glad it all worked out for you.
