kjohnsonmtg 2 Posted September 19, 2014 Posted September 19, 2014 I have Box Sets plugin added and it is working. However, I have a 3D Movies folder which houses all of my 3D Movies which are duplicates of some 2D movies. For example I have a Transformers Movie that is 3D(which is in the 3D folder) and a Transformers Movie that is not 3D in the regular Movies folder. The issue I have is the 3D movies show up in the Box Sets and I do not want the 3D movies showing up in the Box Sets. I also make sure the 3D folder is not grouped with the Movies folder in MB Server. Therefore, you see a separate 3D folder in all of my clients.
bluemonkey07 590 Posted September 19, 2014 Posted September 19, 2014 Can use use the metadata editor to remove the 3d version from the box set and then lock the metadata for that box set?
kjohnsonmtg 2 Posted September 19, 2014 Author Posted September 19, 2014 Can use use the metadata editor to remove the 3d version from the box set and then lock the metadata for that box set? That sounds good, But you have to go through each box set to erase the 3D Movies and then when you get another Movie for that Box Set it will not be included since you have now locked the box set. Sounds like to me the easiest way to get this done is to have the option to exclude folders from Box Sets(or Collections) as they call them..
