kirshman 1 Posted January 29, 2022 Posted January 29, 2022 I have the latest emby server running on a nvidia shield. Then it goes to my roku ultra 2020, to my 7.1 reciever, and then out to the tv and speakers. My question is on the audio. When i rip my blurays and 4k blurays to 7.1 aac, the emby server does direct stream vs direct play on my 5.1 aac files. Any idea why this would be happening? Do i need a different codec for 7.1, or is this something to do with the emby app on the roku? Any direction would be great. Thanks!
Solution roaku 842 Posted January 30, 2022 Solution Posted January 30, 2022 (edited) Rokus have limited multichannel AAC support, depending on the model. I'm not sure if any of them support 7.1 AAC. I know they recommend Dolby Digital+ for 7.1, but there's no consumer/open source option to generate 7.1 DD+. I'm a Roku fan, but I finally bit the bullet and got a Shield recently so I could play my rips with DTS-HD and TrueHD. Based on a web search, it looks like it supports 7.1 AAC too. https://developer.roku.com/docs/specs/media/streaming-specifications.md Edited January 30, 2022 by roaku
Happy2Play 9814 Posted January 30, 2022 Posted January 30, 2022 According to the chart it is limited to AAC 2.0. AAC AC3/E-AC3 DTS Decode/Passthrough Decode on all devices Device specific Passthrough Sampling Rate 44.1 Khz, 48 Khz 48 Khz Passthrough Sample Size 16-bit 16-bit Passthrough Bit rate 32-256 Kbps 96-768 Kbps Passthrough Number of Channels 2.0 2.0, 5.1, 7.1, Atmos Passthrough Multichannel AAC is not supported on all Roku models. Roku TVs, Roku 4, and Roku Ultra set-top-boxes support multichannel decode to PCM stereo.
RanmaCanada 503 Posted January 30, 2022 Posted January 30, 2022 Yeah if you want 7.1 audio you should be using your Shield as you player, not your server.
ebr 16354 Posted January 30, 2022 Posted January 30, 2022 Hi. Did these responses answer your questions? The limitation is the Roku with AAC.
