kjohnsonmtg 2 Posted September 19, 2014 Posted September 19, 2014 I am running MBC with MB Plus and I was wondering if their was a way to add Box Sets in the Default Profile. I see the options under "Show Views" as "Show Years" and "Show Decades" but again would love to see and option for Box Sets or if their is a way to get Box Sets added Please advise.
ebr 16335 Posted September 19, 2014 Posted September 19, 2014 First, make sure you have the option set in your user preferences (in MB Server) to "Show a movie collections view". Then, inside the config screen for the MB Plus Category in which you wish these to appear, select the "Add media folder" button and pick the Collections item that shows up there.
kjohnsonmtg 2 Posted September 19, 2014 Author Posted September 19, 2014 First, make sure you have the option set in your user preferences (in MB Server) to "Show a movie collections view". Then, inside the config screen for the MB Plus Category in which you wish these to appear, select the "Add media folder" button and pick the Collections item that shows up there. That worked perfectly..Thank You..MB Plus has giving me the interface for MBC that MBT and other clients have had. I wanted to stick with Classic because of True Live TV with Cable Card protected content etc(HBO, Showtime and others) but wanted the interface of the newer clients..Thank You Again..
