CheeseSteak 2 Posted January 28, 2022 Posted January 28, 2022 Hello all, Ive been using Emby for years and finally have a use for music. I added my music folder in library settings successfully, and all metadata was collected. The problem is I dont have a Music library on the home screen. Under Settings/Home Screen there is no 'Music' under Library Order. I feel im doing something obviously wrong; like the answer is right in front of my face. The music files follows standard folder structure and there is nothing strange about the location. Restarted the server and the machine its on a few times with no luck. Help make me look like an idiot, -CheeseSteak
Abobader 3485 Posted January 28, 2022 Posted January 28, 2022 Hello CheeseSteak, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Solution GrimReaper 4854 Posted January 28, 2022 Solution Posted January 28, 2022 (edited) 6 minutes ago, CheeseSteak said: Hello all, Ive been using Emby for years and finally have a use for music. I added my music folder in library settings successfully, and all metadata was collected. The problem is I dont have a Music library on the home screen. Under Settings/Home Screen there is no 'Music' under Library Order. I feel im doing something obviously wrong; like the answer is right in front of my face. The music files follows standard folder structure and there is nothing strange about the location. Restarted the server and the machine its on a few times with no luck. Help make me look like an idiot, -CheeseSteak Check your User (edit: Settings>Users tab>click User>Access tab along upper edge) Access settings, is Music library ticked/enabled there. Edited January 28, 2022 by GrimReaper Append 1
CheeseSteak 2 Posted January 28, 2022 Author Posted January 28, 2022 Yes! Jeez man, im getting old. I knew it was obvious, yet I couldn't find it. Thanks for everything guys. As always, love this program. Use it almost daily. Well worth the lifetime premiere subscription. I have my dunce cap on now. Thanks again. -CheeseSteak 2
