OSBuckeyes4Life 12 Posted January 27, 2022 Posted January 27, 2022 I have been having an issue on Live TV and it is with Roku, Firestick, Apple, Android. Just didn't know if I was doing something wrong. It is very sporatic but when it happens I have to restart my server to fix it and then live tv plays again. I recreated it at the bottom of these log files and anything that could help would be greatly appreciated!!! Here is the issue I am seeing. Is it because of free space on the Hard Drive? I do know that is low. Restarting the server is leading me away from that theory. 2022-01-27 08:57:35.380 Info Server: http/1.1 Response 200 to ipaddress. Time: 23ms. http://myserverurl:8096/emby/LiveTv/Programs?UserId=02355f71effb4497a2b923e71dc95a19&MaxStartDate=2022-01-27T21:30:00.000Z&MinEndDate=2022-01-27T13:30:01.000Z&channelIds=981938,982057,981906,982149,982047,982170,982166,982175,981897,981933,982157,982171,1102347,982190&ImageTypeLimit=1&SortBy=StartDate&EnableTotalRecordCount=false&EnableUserData=false&X-Emby-Client=Emby for iOS&X-Emby-Device-Name=Jim's iPhone&X-Emby-Device-Id=6352FCDE-27E3-4FC2-B2FE-30E767ACEEED&X-Emby-Client-Version=2.1.1 2022-01-27 08:57:35.397 Error Server: Error processing request *** Error Report *** Version: 4.6.7.0 Command line: C:\Users\schoe\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.22000 Framework: .NET Core 3.1.21 OS/Process: x64/x64 Runtime: C:/Users/schoe/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 12 Data path: C:\Users\schoe\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\schoe\AppData\Roaming\Emby-Server\system System.InvalidOperationException: System.InvalidOperationException: Operation is not valid due to the current state of the object. at Emby.Server.Implementations.Library.LibraryManager.ConvertImageToLocal(BaseItem item, ItemImageInfo image, Int32 imageIndex, CancellationToken cancellationToken) at Emby.Drawing.ImageProcessor.ProcessImage(ImageProcessingOptions options, CancellationToken cancellationToken) at MediaBrowser.Api.Images.ImageService.GetImage(ImageRequest request, Int64 itemId, BaseItem item, Boolean isHeadRequest) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext() ffmpeg-transcode-9b5eb2b5-1161-4c3e-bb8f-bfaf57c6cc14_1.txt embyserver (1).txt
Luke 42243 Posted February 1, 2022 Posted February 1, 2022 Hi, during the time of this log file, what exactly did you experience, and when?
OSBuckeyes4Life 12 Posted February 2, 2022 Author Posted February 2, 2022 So Live TV, I am pulling a M3U file for TV. It works great after I start up my Machine (Windows 11), but if you try and hit a few shows, it eventually stops working, almost like a hung thread or something. So in this log file, I rotated the log file manually, I hit a few channels, stayed there for 10 seconds, then left that channel and went to another. What happens is it loads the channel but it just spins and spins, then you get an error that states "". They only way I have found to resolve it is by restarting the server. Once it errors, it won't work again until restarted. The errors started at 11:00 PM. I just did this with the same results from a Windows Machine, MacBook Pro and an iPhone. I did delete the beginning of the embyserver file to allow it to fit. embyserver.txt embyserver-63779353198.txt
OSBuckeyes4Life 12 Posted February 2, 2022 Author Posted February 2, 2022 Here is what it looks like, it just spins for about 25 seconds, then I get the error message.
Luke 42243 Posted February 2, 2022 Posted February 2, 2022 I can see we tried to open a connection to your tuner url, but it either timed out or they refused it.
OSBuckeyes4Life 12 Posted February 2, 2022 Author Posted February 2, 2022 Yeah I was looking at logs too to see if I can figure it out. It's very odd. I can close the issue but something isn't adding up.
BillOatman 597 Posted February 2, 2022 Posted February 2, 2022 If this is a m3u file for IPTV from a provider, how many concurrent streams are you allowed by the provider? It's possible the provider doesn't immediately recognize the disconnect of stream 1 and gets a request for a 2nd stream. If that happens and you go over your limit you might see that error (providers usually get unhappy if you do that a lot as well).
OSBuckeyes4Life 12 Posted February 2, 2022 Author Posted February 2, 2022 It shows unlimited, I did look into that too just to make sure.
BillOatman 597 Posted February 2, 2022 Posted February 2, 2022 Unlimited huh, never heard of that before. Nice provider You might want to verify with them that it truly is unlimited though 1
OSBuckeyes4Life 12 Posted February 2, 2022 Author Posted February 2, 2022 Well bang me sideways, it isn't unlimited hahahaha. ok yeah thanks @BillOatman
BillOatman 597 Posted February 2, 2022 Posted February 2, 2022 2 minutes ago, schoepp23 said: Well bang me sideways, it isn't unlimited hahahaha. ok yeah thanks @BillOatman You're welcome
luke79 1 Posted February 21, 2022 Posted February 21, 2022 I am having the very same problem. I only have one stream allowed from my provider, and I am not using it anywhere else. The IPTV works fine when used on standalone apps, but not on Emby. ffmpeg-transcode-2a706750-c907-4466-9abb-94740771c64a_1.txt embyserver.txt
BillOatman 597 Posted February 21, 2022 Posted February 21, 2022 (edited) 4 hours ago, luke79 said: I am having the very same problem. I only have one stream allowed from my provider, and I am not using it anywhere else. The IPTV works fine when used on standalone apps, but not on Emby. ffmpeg-transcode-2a706750-c907-4466-9abb-94740771c64a_1.txt 5.37 kB · 0 downloads embyserver.txt 1.4 MB · 0 downloads Doesn't seem to like your ffmpeg very much. Quote library "libnativehelper.so" not found Also from another thread: Quote Hi. Make sure you do not exit playback in the app by using the remote "Home" button. That has the potential to strand streams because it just kills the app with no warning. Also, this situation should be improved with the next server release. Edited February 21, 2022 by BillOatman
Luke 42243 Posted February 21, 2022 Posted February 21, 2022 4 hours ago, luke79 said: I am having the very same problem. I only have one stream allowed from my provider, and I am not using it anywhere else. The IPTV works fine when used on standalone apps, but not on Emby. ffmpeg-transcode-2a706750-c907-4466-9abb-94740771c64a_1.txt 5.37 kB · 1 download embyserver.txt 1.4 MB · 1 download
