Emby Stuck on Emby Connect
Go to solution Solved by thunderclap,
thunderclap
I've started playing with Emby to see if I want to switch from Plex. First Emby app install went fine on one TCL Roku TV using Emby Connect, but on my second TV it's stuck just after logging in with a pin. I've tried deleting and reinstalling the app as well as rebooting the TCL Roku TV but neither fixed the problem.
I've also backed out of the app and the server is listed with my username, but when it's selected it gets stuck on this screen too. Any ideas?
Edited by mbuhmann
  • Solution
thunderclap
Disregard, I think I got it figured out. Forgot the number one rule of running a server: open the ports on the router.
Thanks for following up.
