usnscpo 24 Posted January 25, 2022 Posted January 25, 2022 920+, Emby Premiere, Sony X900H 4k TV, Denon S930H receiver connected via arc/earc, Gig network. I have several 4k movies encoded in Dolby TrueHD 7.1 which play flawlessly on my equipment without transcoding/remuxing. I recently ripped the 4k 5 movie set of Transformer movies with makeMKV as I always do with all the other 4k movies. For some strange reason, these movies trigger audio transcoding (as per stats for nerds - "audio format not supported"). Playback starts stuttering within about 30 seconds, and locks up within about a min. Hope these logs tell the tale? Hopefully, someone can point me in the right direction towards a solution. Thx guys! ffmpeg-transcode-5658ed37-d454-4dd9-bbab-44325e4e421e_1.txt ffmpeg-remux-c1742fc5-3e50-41ed-8640-da71ecce21fa_1.txt embyserver.txt
Carlo 4561 Posted January 26, 2022 Posted January 26, 2022 I believe the issue you're seeing is the Dolby Enhancement Layer causing issues as MakeMKV probably didn't get the conversion correct. That's typically what the Skipping NAL unit 62/63 are. Do you have any other programs you could use to try and rip the discs with?
usnscpo 24 Posted January 26, 2022 Author Posted January 26, 2022 I don't have another program at this time. I downloaded DVDFab, but when I installed it, I felt like it was some form of malware with the way it presents itself and pushes for you to install "features" and such. It put me off, frankly. Any other suggestions for something that will do DVD, BluRay, & UHD? Cheers!
Happy2Play 9812 Posted January 26, 2022 Posted January 26, 2022 13 hours ago, cayars said: That's typically what the Skipping NAL unit 62/63 are. Doesn't this apply? #5688 (Support hevc NAL units 62 and 63) – FFmpeg
usnscpo 24 Posted January 26, 2022 Author Posted January 26, 2022 @Happy: This is greek to me, however, these disks are Dolby Vision & HDR10, if that makes a difference?
Carlo 4561 Posted January 26, 2022 Posted January 26, 2022 1 hour ago, Happy2Play said: Doesn't this apply? #5688 (Support hevc NAL units 62 and 63) – FFmpeg Looks like it. Doesn't appear to be in any releases yet I don't think.
usnscpo 24 Posted February 15, 2022 Author Posted February 15, 2022 Just circling back to close the loop on this. So even though my TV has eARC/HDMI 2.1 and can can pass TrueHD, my receiver is only ARC/HDMI 2.0, so it was triggering the transcode. Solved by adding a Shield Pro > Receiver > TV. Everything direct plays now. Thanks for the insights! 1 1
