loredan 0 Posted January 25, 2022 Posted January 25, 2022 (edited) Emby Server was discoverable through upnp/dlna in version 4.6.0.50. After updating to 4.6.7.0 - it's not. Observed with VLC Player on Android -> VPN Server + Emby on RPi. Been tracking this. Worked also in 4.6.4.0 (Emby.Dlna.dll 1.0.66.0) but not in 4.6.6.0 (Emby.Dlna.dll 1.0.69.0). This was tested with VLC Player on the same machine as Emby, Win-x64. bug 4.6.6.0 - embyserver-63778749276.txt working 4.6.4.0 - embyserver-63778749204.txt Edited January 25, 2022 by loredan
Luke 42237 Posted January 25, 2022 Posted January 25, 2022 Hi there, please attach the emby server log: Thanks.
loredan 0 Posted January 25, 2022 Author Posted January 25, 2022 (edited) Logs attached. The difference, on these lines, on working 4.6.4.0 appeared a network interface that doesn't on 4.6.6.0 - 192.168.130.2: Info NetworkManager: Detected local ip addresses... Info App: Init BeginReceive on... Info App: SsdpCommunicationsServer disposing sendSocket from... That NIC is a virtual one - VirtualBox. On RPi the same happens with a virtual NIC of Wireguard VPN Server. Edited January 25, 2022 by loredan
Luke 42237 Posted January 25, 2022 Posted January 25, 2022 Hi, there's been recent development on this actually. Do you mind installing the beta server and then providing a new log file? Thanks.
loredan 0 Posted January 25, 2022 Author Posted January 25, 2022 Hi, not fixed Virtual NIC still missing from Detected local ip addresses... VLC Player doesn't detect Emby. logs 4.7.0.21.txt
Happy2Play 9811 Posted January 26, 2022 Posted January 26, 2022 @Lukeshouldn't the user apply LAN networks in a situation like this if discovery is not applying all of them? Looks like Ethernet VirtualBox (Description: VirtualBox Host-Only Ethernet Adapter) is 192.168.x.x and Ethernet NET (Description: Realtek PCIe GbE Family Controller) is 10.19.x.x. But Emby is only detecting Local IP "Ethernet Net".
Luke 42237 Posted January 26, 2022 Posted January 26, 2022 6 minutes ago, Happy2Play said: @Lukeshouldn't the user apply LAN networks in a situation like this if discovery is not applying all of them? Looks like Ethernet VirtualBox (Description: VirtualBox Host-Only Ethernet Adapter) is 192.168.x.x and Ethernet NET (Description: Realtek PCIe GbE Family Controller) is 10.19.x.x. But Emby is only detecting Local IP "Ethernet Net". As a last resort, but we should be able to figure this out automatically.
