thanet31756 0 Posted January 25, 2022 Posted January 25, 2022 Hi, I have a problem with Fast forwarding or skip to specific time is not working on direct play but works on direct stream remotely. But there is no problem when I access it on local network. Any idea on why this would be happening? This is my server details: Emby Version:4.6.7.0 (installed on Synology) I set up the cloud flare tunnel to my Nginx reverse proxy route to the emby media server.
thanet31756 0 Posted January 25, 2022 Author Posted January 25, 2022 I've tried emby app on my ipad, fast forwarding is working but skip to the specific time or select chapter is not working.
thanet31756 0 Posted January 28, 2022 Author Posted January 28, 2022 please help, this is very big issue for me. The resume function is not wokring as well.
Solution Luke 42241 Posted January 28, 2022 Solution Posted January 28, 2022 HI there, please try turning off cloudfare caching and see if that helps.
thanet31756 0 Posted January 28, 2022 Author Posted January 28, 2022 It's working, thanks a lot. You save my life :).
