Mister Steve 30 Posted January 25, 2022 Posted January 25, 2022 Often Emby has trouble seeking for playback position during a recording. When this happens the duration shows a junk number, or NaNNaNNaN, or a fraction of the actual recording time. I'm using an Android phone (screenshot below) and NVIDIA Shield, and seems to only happen if I'm watching then exit and try to resume. It's maddening backing out of playback at half time, only to find you cannot resume and watch the rest of a game. The 2nd half of the Bills-Chiefs game was probably boring and uneventful anyway so I'm sure we didn't miss much. Details below. Example log from Shield playback. It appears Emby first tries HW decoded playback, which fails with "Invalid frame dimensions 0x0. could not seek to position 85621.853" then falls back to SW decoded playback, which fails the same way. Recording is from an HDHomerun Connect Quatro. ----- Operating System: Linux version 5.14.0-0.bpo.2-amd64 (debian-kernel@lists.debian.org) (gcc-10 (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35.2 OS/Process: x64/x64 Emby Server version: 4.6.7.0 Operating system: Unix 5.14.0.0 >>>>>> User policy for emby EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True >>>>>> Affected codecs Encoder VAAPI RocketLake-S GT1 UHD Graphics 750 - H.264 (AVC) Adapter #0: 'RocketLake-S GT1 UHD Graphics 750' Id:19594 (Driver: Intel iHD driver for Intel(R) Gen Graphics - 21.2.2 (1dd7d7f), Vendor: Intel Corporation) Frame Sizes: 32x32...4096x4096 Color Formats: NV12 Profiles: Main Profile (Level 6), High Profile (Level 6), Constrained Baseline Profile (Level 6) Decoder VAAPI RocketLake-S GT1 UHD Graphics 750 - MPEG-2 Adapter #0: 'RocketLake-S GT1 UHD Graphics 750' Id:19594 (Driver: Intel iHD driver for Intel(R) Gen Graphics - 21.2.2 (1dd7d7f), Vendor: Intel Corporation) Frame Sizes: max 2048x2048 Color Formats: NV12 Profiles: Simple Profile (High Level), Main Profile (High Level) >>>>>> FindVideoEncoder - Media: h264, UseHardwareCodecs: True, Mode: Custom Info Checking: 'VAAPI RocketLake-S GT1 UHD Graphics 750 - H.264 (AVC)' Info Check successful - selecting 'VAAPI RocketLake-S GT1 UHD Graphics 750 - H.264 (AVC)' >>>>>> FindVideoDecoder - MediaType: mpeg2video, Mode: Custom Info Checking: 'VAAPI RocketLake-S GT1 UHD Graphics 750 - MPEG-2' Info Check successful - selecting 'VAAPI RocketLake-S GT1 UHD Graphics 750 - MPEG-2' >>>>>> Processing Plan Info Name CanDoInHardware WillDoInHardware Reason Info VAAPI RocketLake-S GT1 UHD Graphics 7... >> True True Hardware Codec Info VideoInput >> True True Same adapter (/dev/dri/renderD128), s... Info Deinterlace >> True True Info VideoOutput >> True True Hardware encoder Info VAAPI RocketLake-S GT1 UHD Graphics 7... >> True True Hardware Codec >>>>>> Projected Processing Formats Info Previous HW-Context Format SW-Format Size Next Info mpeg2video >> VAAPI vaapi_vld nv12 1920x1080 >> deinterlace_vaapi Info deinterlace_vaapi >> VAAPI vaapi_vld nv12 1920x1080 >> /opt/emby-server/bin/ffmpeg -loglevel +timing -y -print_graphs_file "/var/lib/emby/logs/ffmpeg-transcode-xxxx_1graph.txt" -copyts -start_at_zero -analyzeduration 3000000 -f mpegts -ss 01:43:52.112 -c:v:0 mpeg2video -hwaccel:v:0 vaapi -hwaccel_device:v:0 /dev/dri/renderD128 -hwaccel_output_format:v:0 vaapi -i "http://127.0.0.1:8096/LiveTv/LiveRecordings/xxxx/stream" -filter_complex "[0:0]deinterlace_vaapi@f1[f1_out0]" -map [f1_out0] -map 0:1 -sn -c:v:0 h264_vaapi -b:v:0 15000000 -g:v:0 90 -maxrate:v:0 15000000 -bufsize:v:0 30000000 -sc_threshold:v:0 0 -keyint_min:v:0 90 -r:v:0 29.970029830932617 -profile:v:0 high -level:v:0 4 -c:a:0 copy -metadata:s:a:0 language=eng -disposition:a:0 default -fflags +discardcorruptts+fillwallclockdts -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list "/srv/dev-disk-by-uuid-xxxx/emby/transcode/transcoding-temp/649C7B.m3u8" -segment_list_type m3u8 -segment_time 3 -segment_list_entry_prefix hls/649C7B/ -segment_start_number 0 -individual_header_trailer 0 -write_header_trailer 0 -segment_write_temp 1 "/srv/dev-disk-by-uuid-xxxx/emby/transcode/transcoding-temp/649C7B_%d.ts" 21:30:57.256 ffmpeg version 4.3.0-emby_2021_02_27 Copyright (c) 2000-2021 the FFmpeg developers and softworkz for Emby LLC 21:30:57.256 built with gcc 8.3.0 (crosstool-NG 1.24.0) 21:30:57.256 Execution Date: 2022-01-23 21:30:57 21:30:57.265 [mpeg2video @ 0x25cb840] Invalid frame dimensions 0x0. Last message repeated 24 times 21:30:57.271 http://127.0.0.1:8096/LiveTv/LiveRecordings/xxxx/stream: could not seek to position 85621.853 21:30:57.271 Input #0, mpegts, from 'http://127.0.0.1:8096/LiveTv/LiveRecordings/xxxx/stream': 21:30:57.271 Duration: N/A, start: 79389.741000, bitrate: N/A Info Previous transcoding attempt failed. Falling back to software transcoding. >>>>>> FindVideoDecoder - MediaType: mpeg2video, Mode: Custom Info Checking: 'Automatic software decoder' Info Check successful - selecting 'Automatic software decoder' >>>>>> Processing Plan Info Name CanDoInHardware WillDoInHardware Reason Info Automatic software decoder >> False False Software Codec Info VideoInput >> False False Not a hardware decoder Info Deinterlace >> False False Info VideoOutput >> False False Not a hardware encoder Info libx264 Software Encoder >> False False Software Codec >>>>>> Projected Processing Formats Info Previous HW-Context Format SW-Format Size Next Info mpeg2video >> - yuv420p yuv420p 1920x1080 >> yadif Info yadif >> - yuv420p yuv420p 1920x1080 >> ... 21:31:12.932 ffmpeg version 4.3.0-emby_2021_02_27 Copyright (c) 2000-2021 the FFmpeg developers and softworkz for Emby LLC 21:31:12.932 built with gcc 8.3.0 (crosstool-NG 1.24.0) 21:31:12.932 Execution Date: 2022-01-23 21:31:12 21:31:12.938 [mpeg2video @ 0x185e6c0] Invalid frame dimensions 0x0. Last message repeated 24 times 21:31:12.943 http://127.0.0.1:8096/LiveTv/LiveRecordings/xxxx/stream: could not seek to position 85621.853 21:31:12.943 Input #0, mpegts, from 'http://127.0.0.1:8096/LiveTv/LiveRecordings/xxxx/stream': 21:31:12.943 Duration: N/A, start: 79389.741000, bitrate: N/A Any ideas? 1
ebr 16335 Posted January 25, 2022 Posted January 25, 2022 10 minutes ago, Mister Steve said: The 2nd half of the Bills-Chiefs game was probably boring and uneventful anyway so I'm sure we didn't miss much LOL Hi. I hope you really did catch it. Seeking/resuming while recording is a tricky area right now. We are working on improving it. 1
Mister Steve 30 Posted January 25, 2022 Author Posted January 25, 2022 18 minutes ago, ebr said: LOL Hi. I hope you really did catch it. Seeking/resuming while recording is a tricky area right now. We are working on improving it. That's good to hear. We went on a news blackout and resumed watching the next morning after the recording completed.
MBSki 1115 Posted January 25, 2022 Posted January 25, 2022 20 minutes ago, Mister Steve said: That's good to hear. We went on a news blackout and resumed watching the next morning after the recording completed. Same here. And as a Bills fan I probably should've just deleted the recording and pretended that the game never happened.
Carlo 4561 Posted February 8, 2022 Posted February 8, 2022 On 1/25/2022 at 10:28 AM, mbarylski said: Same here. And as a Bills fan I probably should've just deleted the recording and pretended that the game never happened. More like pretend the Bills never happened. LOL 1
