tp546 41 Posted September 18, 2014 Posted September 18, 2014 Hey guys, I am trying to map a button to my Harmony One that will start MB and my initial thought was to use a keyboard shortcut and then program that into my remote, but every time MBC gets updated, it wipes out the shortcut settings. Can someone who has a similar setup give me any advice on how to deal with that problem? Thanks!
ebr 16335 Posted September 18, 2014 Posted September 18, 2014 If you drag a shortcut to the taskbar (win 7) then you can use Winkey+[index of item on taskbar] to launch it. That should survive updates...
tp546 41 Posted September 18, 2014 Author Posted September 18, 2014 I tried that actually and it didn't. Maybe if I create a shortcut manually and give it a keyboard shortcut it won't get deleted during updates?
ebr 16335 Posted September 18, 2014 Posted September 18, 2014 Yep, that should work. So should what I said but you'd need to drag a copy of it to the task bar.
Cheesegeezer 3106 Posted September 19, 2014 Posted September 19, 2014 I tried that actually and it didn't. Maybe if I create a shortcut manually and give it a keyboard shortcut it won't get deleted during updates? Tp not sure if this will help but have a read of this tut i wrote Cheers http://mediabrowser.tv/community/index.php?/topic/1091-launching-mbc-andor-mbt-directly-from-your-logitech-harmony-remote/ Sent from my iPhone using my finger
