easystreams 0 Posted September 18, 2014 Posted September 18, 2014 I have a Pivos Xios, installed XBMB3C which seems to be fine and enabled this and entered the server address as for example in this case would be 146.63.56.388 and then port number as 8086 and username and password but it come us with following 'Script error' I have media browser on my Windows PC running and all on same network, and also have installed XBMC on my windows PC then installed the XBMB3C on the windows XBMC, inputting all same server details and port number and username/password correctly and this works fine on my PC without script error but has script errors on my Pivos box? Any ideas would be welcome in resolving this...have reset box, turned off and on, input all data again but still get script errors...even loaded XBMB3C from xbmc.org but still script errors unable to run???
im85288 1493 Posted September 18, 2014 Posted September 18, 2014 Please post your xbmc log as without this we have no way to even start looking into the issue.
mguebert 10 Posted September 18, 2014 Posted September 18, 2014 I have just started experimenting with using Open Elec 13.1 and XBMB3C and I have noticed a similar issue. It seems to have to do with the views. For instance if I use all movies view it works great. If I select movies or collections for instance I get the script error. I will post logs when I get a chance.
easystreams 0 Posted September 20, 2014 Author Posted September 20, 2014 here is log file at following link http://xbmclogs.com/show.php?id=298456&mode=raw
xnappo 1611 Posted September 20, 2014 Posted September 20, 2014 Hmm - it is just timing out trying to connect to the server. You can ping your server from this machine ok? xnappo 21:33:54 T:1418204256 ERROR: Exception in thread Thread-1: Traceback (most recent call last): File "/usr/lib/python2.7/threading.py", line 530, in __bootstrap_inner File "/root/.xbmc/addons/plugin.video.xbmb3c/resources/lib/InProgressItems.py", line 71, in run self.updateInProgress() File "/root/.xbmc/addons/plugin.video.xbmb3c/resources/lib/InProgressItems.py", line 103, in updateInProgress jsonData = downloadUtils.downloadUrl(recentUrl, suppress=False, popup=1 ) File "/root/.xbmc/addons/plugin.video.xbmb3c/resources/lib/DownloadUtils.py", line 234, in downloadUrl conn.request(method=type, url=urlPath, headers=head) File "/usr/lib/python2.7/httplib.py", line 941, in request File "/usr/lib/python2.7/httplib.py", line 975, in _send_request File "/usr/lib/python2.7/httplib.py", line 937, in endheaders File "/usr/lib/python2.7/httplib.py", line 797, in _send_output File "/usr/lib/python2.7/httplib.py", line 759, in send File "/usr/lib/python2.7/httplib.py", line 740, in connect File "/usr/lib/python2.7/socket.py", line 571, in create_connection timeout: timed out
easystreams 0 Posted September 21, 2014 Author Posted September 21, 2014 The XBMB3C is on pivos xios running linux and downloaded the file from both super repo and also on XBMC.org addons so cannot ping this and if I could would not resolve issues as this is coming from external server
easystreams 0 Posted September 21, 2014 Author Posted September 21, 2014 Pinged my address and it's fine but still script error
easystreams 0 Posted September 22, 2014 Author Posted September 22, 2014 Still no joy. Running XBMB3C from local host and also remote host IP but still not working!!!!!!!
xnappo 1611 Posted September 22, 2014 Posted September 22, 2014 (edited) Sorry - all I can see is that the connection to the server is timing out. I know there is someone else with a Pivos running successfully - hopefully they will chime in. Possibly if you turn debug logging on to level 1(in the addon Advanced settings) and repost it will give me a hint as to the problem. xnappo Edited September 22, 2014 by xnappo
boywhosetsfire 12 Posted September 22, 2014 Posted September 22, 2014 Can't provide any help, but it's not a general problem with a Pivos. One of my devices is Pivos Xios DS and it's running fine there.
easystreams 0 Posted September 23, 2014 Author Posted September 23, 2014 I will post a log shortly on this. It is strange...my Pivos running perfectly with other channels and repositories, just this one not working...mirrored everything from my Windows Pc onto Pivos with all IP addresses, port numbers user login...etc, and checked all settings are identical in which they are and runs on windows PC but not on Pivos Xios with Linux build. I have even also used remote path address to see if this resolves issues but alas it does not. sometime also noticed it either says now 'script error' or 'unable to find host' so something weird going on...however will post another log xnappo
easystreams 0 Posted September 26, 2014 Author Posted September 26, 2014 Here is following log files from my Pivos Xios. There is no debugging level 1 just debugging on/off. I hacve 2 results. First link is using my local host which is 192.168.1.XX and gives error 'unable to connect to host' Link 2 is using remote server address 192.XX.XX.XX (address from server configuration in mediabrowser, port 8096 but gives 'script error' http://xbmclogs.com/show.php?id=303243 http://xbmclogs.com/show.php?id=303242
easystreams 0 Posted September 28, 2014 Author Posted September 28, 2014 (error: ' Script Error!: MediaBrowser.XBMC') This is also updated logs . First log is with 'Debug 2' enabled and 2nd log is with' Info1' enabled for debugging 1st log http://xbmclogs.com/show.php?id=305127 2nd Log http://xbmclogs.com/show.php?id=305125
