Bingo61 2 Posted January 24, 2022 Posted January 24, 2022 I have problem with Emby Server Beta for DS215j (DSM 6.2.4-25556 Update 3) I can install , but it is not possible to "run" , actual version of server, for example: https://github.com/MediaBrowser/Emby.Releases/releases/download/4.7.0.20/emby-server-synology_4.7.0.20_armv7.spk Last working version i can install and run is: 4.7.0.17_armv7.spk.
Luke 42243 Posted January 25, 2022 Posted January 25, 2022 Hi there, what happens when you try to run it?
Carlo 4561 Posted January 25, 2022 Posted January 25, 2022 @Bingo61 What exactly happens when you try to run it? Are you able to SSH into the machine and look at the logs?
Bingo61 2 Posted January 25, 2022 Author Posted January 25, 2022 (edited) After the message that 4.7.0.20armv7.apk was installed successfully. , I press "run". After a long moment of the circle spinning on the screen, the "run" key returns and Emby still does not work. I repeated this process several times. The same thing happens with: 4.7.0.18armv7.apk and 4.7.0.19armv7.apk. Only 4.7.0.17armv7.apk installs and starts properly. No. I'm not able now to SSH into the machine and look at the logs. Edited January 25, 2022 by Bingo61
Bingo61 2 Posted January 25, 2022 Author Posted January 25, 2022 Yes. reebot did not help. Something changed between 4.7.0.17 and 4.7.0.18. After each relase the new version I try it to instal, and error is the same -install sucessful but server did not start. So I have to uninstall new version and come back to 4.7.0.17. Now , I will try install once again 4.7.0.20, and I will try to find logs in emby folder, even it will not work. I will send it in next post.
Carlo 4561 Posted January 25, 2022 Posted January 25, 2022 @Bingo61 If you like I can remote in and take a look to see if I see an issue. Have you by any chance went back to the last working version you had previously?
Bingo61 2 Posted January 25, 2022 Author Posted January 25, 2022 I try install 4.7.0.20 without success - install ok, but RUN not work. Logs folder in emby catalogue is empty. So I don't help Come back to 4.7.0.17
Bingo61 2 Posted February 14, 2022 Author Posted February 14, 2022 Unable to launch last beta version 4.7.0.23. The last working version is still 4.7.0.17. I am waiting for a solution.
alucryd 318 Posted February 16, 2022 Posted February 16, 2022 I will be updating the mono package to support the DS215j later today, according to the logs @cayars sent, you are getting a segfault, which means the dotnet runtime has an issue on your architecture (which sadly isn't found in any other NAS device I know of so I can't rule out a Synology bug). 1
Carlo 4561 Posted February 16, 2022 Posted February 16, 2022 Let us know when it's ready @alucryd as @Bingo61 and I can setup a remote session to do the install and I can grab any logs if needed if the problem persists. 1
alucryd 318 Posted February 16, 2022 Posted February 16, 2022 There you go https://github.com/MediaBrowser/Emby.Releases/releases/download/4.7.0.23/emby-server-synology-mono_4.7.0.23_armv7_legacy.spk 1
Bingo61 2 Posted February 17, 2022 Author Posted February 17, 2022 Problem has been solved. 4.7.0.23-beta works fine on DS215J DSM6 Thanks to everyone for your help, especially thanks to Cayars ,Alucryd and Luke 1
Carlo 4561 Posted February 20, 2022 Posted February 20, 2022 @Bingo61 Have you tried installing .24 yet? You should be able to access it easily with the instructions I gave you.
Bingo61 2 Posted February 20, 2022 Author Posted February 20, 2022 Yes. I have installed .24 few days ago and works fine. Thank You for instructions and professional help.
Bingo61 2 Posted February 20, 2022 Author Posted February 20, 2022 I think it is necessary to remove information from site : https://emby.media/synology6-server.html section Beta , about DS215J : "ARMv7 - Supported models: armada375: DS115, DS215j" Because file is not correct for DS215J , it is not "mono". 1
Luke 42243 Posted February 21, 2022 Posted February 21, 2022 1 hour ago, Bingo61 said: I think it is necessary to remove information from site : https://emby.media/synology6-server.html section Beta , about DS215J : "ARMv7 - Supported models: armada375: DS115, DS215j" Because file is not correct for DS215J , it is not "mono". We'll take a look at it. Thanks. 1
