fallenwitch3r 45 Posted January 24, 2022 Posted January 24, 2022 Are there any plans for a rating system where emby users can rate their content and synchronize this ratings with one of the big providers like IMDb or something else? It would be great that those ratings are used to recommend movies from the emby database for the user. The emby recommendation system that shows similar movies or series are bad. For example. I watched Blade and emby shows me similar movies like Pinocchio, ice age and American pie. None of these movies are similar to blade 2 1
ebr 16338 Posted January 24, 2022 Posted January 24, 2022 1 minute ago, fallenwitch3r said: I watched Blade and emby shows me similar movies like Pinocchio, ice age and American pie. None of these movies are similar to blade What are the genres on the ones suggested compared to the one you watched?
fallenwitch3r 45 Posted January 24, 2022 Author Posted January 24, 2022 Action, romantic, Comedy etc.Â
ebr 16338 Posted January 24, 2022 Posted January 24, 2022 36 minutes ago, fallenwitch3r said: Action, romantic, Comedy etc. So they all share at least one genre, correct?
fallenwitch3r 45 Posted January 24, 2022 Author Posted January 24, 2022 No. Blade hasn't that genre romantic or comedy..
GrimReaper 4899 Posted January 24, 2022 Posted January 24, 2022 2 hours ago, fallenwitch3r said: The emby recommendation system that shows similar movies or series are bad. For example. I watched Blade and emby shows me similar movies like Pinocchio, ice age and American pie. FWIW I have no rogue items in Blade's More Like This: 1
Happy2Play 9813 Posted January 24, 2022 Posted January 24, 2022 Specific examples are needed but as ebr mention I believe only one genre is needed to match. But I know mine appear correct  1 hour ago, fallenwitch3r said: Action, romantic, Comedy etc. Well if this is for Blade I would ask where it came from.  Pinocchio/Ice Age/American Pie are Comedy so it would match.
TechnoMonster 2 Posted September 4, 2023 Posted September 4, 2023 I'd also like a way to rate all of my music videos, on a scale from 1 to 10, and then be able to display that rating easily and even sort by the rating. (Plex had a 1 to 5 star rating feature) 1
