Bazzu85 22 Posted April 25, 2022 Author Posted April 25, 2022 6 hours ago, Luke said: I feel like we should be able to solve this client side within the app. Mpeg4 is not a complex format. I would think the device can handle it with software decoding if the hardware decoder doesn't handle it very well. The hard part is making the decision whether to do that or not. Does this happen with all divx or do you have some that play fine? In all my test all divx and xvid wasn't playing..
Luke 42244 Posted April 25, 2022 Posted April 25, 2022 OK can you please try this version: https://www.dropbox.com/s/u1obwrckg4lkjc8/emby-android-google-armeabi-v7a-release.apk?dl=0 And then provide a log from the android app: Thanks.
Bazzu85 22 Posted April 26, 2022 Author Posted April 26, 2022 On 25/04/2022 at 15:42, Luke said: OK can you please try this version: https://www.dropbox.com/s/u1obwrckg4lkjc8/emby-android-google-armeabi-v7a-release.apk?dl=0 And then provide a log from the android app: Thanks. 1. I installed the provided apk 2. started playing the content in direct play 3. Video issue appear here's the log from the tv: 5e3fce3c-c720-4c79-a9f1-3ba12a3d50f6.log
Luke 42244 Posted April 26, 2022 Posted April 26, 2022 Thanks. Can you provide a sample video for testing? We need to learn if this is a device specific problem or not. Thanks.
Bazzu85 22 Posted April 27, 2022 Author Posted April 27, 2022 (edited) 15 hours ago, Luke said: Thanks. Can you provide a sample video for testing? We need to learn if this is a device specific problem or not. Thanks. I replied to the previous PM message that I sended youin january 29 with the tests files.. let me know Edited April 27, 2022 by Bazzu85
Luke 42244 Posted July 13, 2022 Posted July 13, 2022 Hi, can you please try the latest sideload build and let us know how that compares? https://emby.media/emby-for-android.html Thanks. 1
Bazzu85 22 Posted July 28, 2022 Author Posted July 28, 2022 On 13/07/2022 at 20:06, Luke said: Hi, can you please try the latest sideload build and let us know how that compares? https://emby.media/emby-for-android.html Thanks. Tested with last sideloaded app. Same behaviour.
Luke 42244 Posted July 28, 2022 Posted July 28, 2022 The latest version is 3.2.61. Can you please try that? Thanks !
Bazzu85 22 Posted August 4, 2022 Author Posted August 4, 2022 On 28/07/2022 at 22:59, Luke said: The latest version is 3.2.61. Can you please try that? Thanks ! Here's
Luke 42244 Posted January 5, 2023 Posted January 5, 2023 Are you still having an issue with this using the latest versions?
Luke 42244 Posted January 18, 2023 Posted January 18, 2023 Can you try updating to the latest version of the sideload build? https://emby.media/emby-for-android.html We've updated our embedded video player to the latest version. Let's see if it plays better with that. Thanks !
Bazzu85 22 Posted January 19, 2023 Author Posted January 19, 2023 15 hours ago, Luke said: Can you try updating to the latest version of the sideload build? https://emby.media/emby-for-android.html We've updated our embedded video player to the latest version. Let's see if it plays better with that. Thanks ! Tried. Same bug. 1
Luke 42244 Posted July 28, 2023 Posted July 28, 2023 @Bazzu85can you try the latest build of the standard app and see if it's any different? It has updated video player libraries. https://emby.media/emby-for-android.html Thanks.
Bazzu85 22 Posted February 21, 2024 Author Posted February 21, 2024 On 09/01/2024 at 23:44, Luke said: @Bazzu85? Hi, tried just now with no luck. Videos with Xvid codec doesn't play on my sony bravia. With standard app: With sideloaded android app: Tv info's
ebr 16337 Posted February 21, 2024 Posted February 21, 2024 Hi. Use the playback correction to cause a transcode. XVid is very problematic on modern devices.
