Luke 42244 Posted March 20, 2022 Posted March 20, 2022 Are you still having an issue with this? Can you please try the latest update to our standard android app? https://emby.media/emby-for-android.html
Bazzu85 22 Posted March 20, 2022 Author Posted March 20, 2022 8 minutes ago, Luke said: Are you still having an issue with this? Can you please try the latest update to our standard android app? https://emby.media/emby-for-android.html Yes I'm still having problems with all not h264/h265 content.. I'll try the standard app ASAP
Bazzu85 22 Posted March 20, 2022 Author Posted March 20, 2022 1 hour ago, Luke said: Are you still having an issue with this? Can you please try the latest update to our standard android app? https://emby.media/emby-for-android.html Not working..
Bazzu85 22 Posted March 21, 2022 Author Posted March 21, 2022 On 20/03/2022 at 16:52, Luke said: Are you still having an issue with this? Can you please try the latest update to our standard android app? https://emby.media/emby-for-android.html @Luke please follow me... 1. the not h264/h265 are not playing well on tv, android tv app and standard android app 2. converting this content to h264 with handbrake make the video playing well on both app 3. forcing to transcode during the play, give error (see first posts) 4. we need a way to start this type of content NOT DIRECT PLAYING , to check if the transcode from the start works.. 5. if point 4. works, this type of problem on this devices need to be isolated so the server can send this contents in transcode mode Am I missing something?
Bazzu85 22 Posted March 27, 2022 Author Posted March 27, 2022 @Luke the problem is that emby assumes that my device (sony XH90) can play DIVX or XVID content but it don't.. how can I tell emby to not direct playing this contents?
ebr 16337 Posted March 27, 2022 Posted March 27, 2022 42 minutes ago, Bazzu85 said: how can I tell emby to not direct playing this contents? Hi. You can use the "Playback correction" option in the cog menu during playback.
Bazzu85 22 Posted March 27, 2022 Author Posted March 27, 2022 22 minutes ago, ebr said: Hi. You can use the "Playback correction" option in the cog menu during playback. Not working.. Check this: https://youtu.be/zrp05o-DdB4
ebr 16337 Posted March 28, 2022 Posted March 28, 2022 19 hours ago, Bazzu85 said: Not working.. Check this: https://youtu.be/zrp05o-DdB4 Can you please attach all ffmpeg logs that were created during that session?
Bazzu85 22 Posted March 28, 2022 Author Posted March 28, 2022 7 hours ago, ebr said: Can you please attach all ffmpeg logs that were created during that session? I replicated the same behaviour right now.. here's the logslogs 20220328 2248.zip
ebr 16337 Posted March 29, 2022 Posted March 29, 2022 15 hours ago, Bazzu85 said: I replicated the same behaviour right now.. here's the logslogs 20220328 2248.zip You played a single item and used the Playback correction twice and it produced all of those logs? If you disable hardware transcoding on your server, does it work?
Bazzu85 22 Posted March 30, 2022 Author Posted March 30, 2022 On 29/03/2022 at 14:31, ebr said: You played a single item and used the Playback correction twice and it produced all of those logs? If you disable hardware transcoding on your server, does it work? if you check the video carefully you see this steps: - started playing the problematic video S01-E01-E02 - clicked on playback correction - the client say's too many errors and jump to the next S01-E03-E04 - initialy if you check is "Direct" and suddenly "Transcod" and again "too many errors" and jump to next When I sended the log I stopped the player at S01-E07-E08 I think... And BTW disabling hardware transcoding have the same behaviour
ebr 16337 Posted March 30, 2022 Posted March 30, 2022 Can you please turn off the auto episode queuing and just play one item until it fails and provide just the logs from that? Thanks.
Bazzu85 22 Posted March 30, 2022 Author Posted March 30, 2022 5 hours ago, ebr said: Can you please turn off the auto episode queuing and just play one item until it fails and provide just the logs from that? Thanks. here's. 20220330 2308.zip disabling the queuing, after hitting the playback correction the popup "too many errors" appears and the player closed..
ebr 16337 Posted March 30, 2022 Posted March 30, 2022 Hi. Did you send the log from the app as well? It is already transcoding so there isn't anywhere for it to fall back. I notice HW accel is still on. Usually, these types of issues can be eliminated by using software instead. Can I see a log with the HW disabled?
Bazzu85 22 Posted March 30, 2022 Author Posted March 30, 2022 (edited) 5 minutes ago, ebr said: Hi. Did you send the log from the app as well? It is already transcoding so there isn't anywhere for it to fall back. I notice HW accel is still on. Usually, these types of issues can be eliminated by using software instead. Can I see a log with the HW disabled? yes, I re-enabled it after you asked to disable... here's the log with: - hardware transcoding disabled - queuing disabled 20220331 0011.zip edit: sended additionaly the logs from the app Edited March 30, 2022 by Bazzu85
ebr 16337 Posted March 31, 2022 Posted March 31, 2022 This could be a problem with the TV's decoders but it simply cannot deal with this video - even when transcoded. Have you tried re-muxing or re-encoding it just to see if that fixes it?
Bazzu85 22 Posted March 31, 2022 Author Posted March 31, 2022 Just now, ebr said: This could be a problem with the TV's decoders but it simply cannot deal with this video - even when transcoded. Have you tried re-muxing or re-encoding it just to see if that fixes it? I have 2 version of that episode.. the one transcoded to h264 with handbrake play's fine.. This is the reason why I asked how can I tell to emby that my tv doesn't support codec exept h264/h265..
ebr 16337 Posted March 31, 2022 Posted March 31, 2022 1 minute ago, Bazzu85 said: This is the reason why I asked how can I tell to emby that my tv doesn't support codec exept h264/h265 That wouldn't help in this instance. We are already transcoding it to h264 and the device still cannot play it.
Bazzu85 22 Posted March 31, 2022 Author Posted March 31, 2022 54 minutes ago, ebr said: That wouldn't help in this instance. We are already transcoding it to h264 and the device still cannot play it. We are testing the trascoding using the playback correction function.. the are you sure that the function is not broken?
ebr 16337 Posted April 1, 2022 Posted April 1, 2022 You can see in your logs that we are transcoding to h264 but the device still cannot play the content.
ebr 16337 Posted April 5, 2022 Posted April 5, 2022 4 hours ago, Bazzu85 said: have you found something @ebr? Hi. Nothing beyond this at this time: On 3/31/2022 at 8:49 AM, ebr said: This could be a problem with the TV's decoders but it simply cannot deal with this video - even when transcoded. Have you tried re-muxing or re-encoding it just to see if that fixes it?
Luke 42244 Posted April 8, 2022 Posted April 8, 2022 On 3/21/2022 at 12:17 PM, Bazzu85 said: @Luke please follow me... 1. the not h264/h265 are not playing well on tv, android tv app and standard android app 2. converting this content to h264 with handbrake make the video playing well on both app 3. forcing to transcode during the play, give error (see first posts) 4. we need a way to start this type of content NOT DIRECT PLAYING , to check if the transcode from the start works.. 5. if point 4. works, this type of problem on this devices need to be isolated so the server can send this contents in transcode mode Am I missing something? Can you try side loading the latest version of the standard app and see how that compares? Thanks.
Bazzu85 22 Posted April 9, 2022 Author Posted April 9, 2022 (edited) On 08/04/2022 at 23:30, Luke said: Can you try side loading the latest version of the standard app and see how that compares? Thanks. Sideloaded 3.2.45. trying the usual test file: Emby try always to direct play The video problem remains as usual on the tv I tried to force the transcode changing the quality from the player options and the app is able to reproduce the transcoded content.. the android tv app trying to transcode fails as usual.. This can be an initial workaround. Not a solution obviously. The solution is definitely start this content in transcode mode, and not in direct play.. thanks Edited April 13, 2022 by Bazzu85
Luke 42244 Posted April 24, 2022 Posted April 24, 2022 I feel like we should be able to solve this client side within the app. Mpeg4 is not a complex format. I would think the device can handle it with software decoding if the hardware decoder doesn't handle it very well. The hard part is making the decision whether to do that or not. Does this happen with all divx or do you have some that play fine?
