ginjaninja 605 Posted January 23, 2022 Posted January 23, 2022 When Auto Organise imports an episode of a show configured for an alternative display order. Could/should the %en title variable respect the title of the currently selected display order. Eg. With show set to display order=DVD Wonderfalls - S01E02.mp4 should be imported as Wonderfalls - S01E02 - Pink Flamingos.mp4 not Wonderfalls - S01E02 - Karma Chameleon.mp4 thanks for considering 1
chef 3811 Posted January 23, 2022 Posted January 23, 2022 1 hour ago, ginjaninja said: When Auto Organise imports an episode of a show configured for an alternative display order. Could/should the %en title variable respect the title of the currently selected display order. Eg. With show set to display order=DVD Wonderfalls - S01E02.mp4 should be imported as Wonderfalls - S01E02 - Pink Flamingos.mp4 not Wonderfalls - S01E02 - Karma Chameleon.mp4 thanks for considering Hi @ginjaninja! Good to hear from ya! I'm just trying to understand what it is that auto organize is missing here. Did it mis-identify the episode? Could you explain a little more?
ginjaninja 605 Posted January 23, 2022 Author Posted January 23, 2022 1 hour ago, chef said: Hi @ginjaninja! Good to hear from ya! I'm just trying to understand what it is that auto organize is missing here. Did it mis-identify the episode? Could you explain a little more? sure i have a show Wonderfalls configured for DVD display order and auto organise configured with episode naming So when i organise Wonderfalls - S01E02.mp4 i would like the episode to be named Wonderfalls - S01E02 - Pink Flamingos.mp4 (as per dvd order, wanted behaviour) not Wonderfalls - S01E02 - Karma Chameleon.mp4 (as per aired order, observed behaviour) 2 hours ago, chef said: Did it mis-identify the episode? no, AO has detected everything correctly, but it hasnt named the episode as per title of my selected display order. 1
chef 3811 Posted January 23, 2022 Posted January 23, 2022 Ah okay, so the ItemLookup() in Auto Organize is not honoring the the option you select. Is the "Display Order" option part of the metadata editor?
Happy2Play 9814 Posted January 23, 2022 Posted January 23, 2022 14 minutes ago, chef said: Is the "Display Order" option part of the metadata editor? Yes, Series level as shown above.
chef 3811 Posted January 24, 2022 Posted January 24, 2022 I have found the code that requests provider data for episodes. var searchResults = await _providerManager.GetRemoteSearchResults<Episode, EpisodeInfo>(new RemoteSearchQuery<EpisodeInfo> { SearchInfo = episodeInfo }, series, cancellationToken); I was hoping to get some query options for the metadata, but this doesn't seem to be the case. The options that are accessible in the Provider are: "IncludedDisabledProviders", "SearchInfo", "ItemId", and "SearchProviderName". But nothing that immediately stands out to help us there. My second thought is that the ProviderManager should adhere to the the options set in the main application. If it isn't following the Display Order option, then does that mean that it is not doing this?? I will keep trying.
AdrianW 1058 Posted March 21, 2022 Posted March 21, 2022 I just came across this problem myself. I set a new series to "Absolute order" but Auto Organise named the episodes based on the default "Aired order". I ended up having to manually move and rename the files before getting Emby to do a rescan.
