VicMoore 755 Posted January 21, 2022 Posted January 21, 2022 (edited) When fetching items it's possible to filter on MinOfficialRatings and MaxOfficialRatings. The option in the URL requires one of the rating codes below. For example, "MinOficialRating=TV-G." Can more than one rating code be used simultaneously? For example, " MinOficialRating=TV-G/EC/G" Do the codes prefixed with "TV" apply only to tv shows? Or can they also be applied to movies? Can I use the weight number as the parameter? For example, "MinOfficialRating=5" Thanks for your help, Vic APPROVED,1 G,1 E,1 EC,1 TV-G,1 TV-Y,2 TV-Y7,3 TV-Y7-FV,4 PG,5 TV-PG,5 PG-13,7 T,7 TV-14,8 R,9 M,9 TV-MA,9 NC-17,10 AO,15 RP,15 UR,15 NR,15 X,15 XXX,100 Edited January 21, 2022 by VicMoore
ebr 16332 Posted January 21, 2022 Posted January 21, 2022 Hi. Only one is necessary because it will translate to the numeric rating. 1
VicMoore 755 Posted January 21, 2022 Author Posted January 21, 2022 Thanks, it's good to learn something everyday. Vic
