fidji 3 Posted September 17, 2014 Posted September 17, 2014 Hello, I was using Gamebrowser 2 until I switch to MB3. I configure DOS, Windows, Playstation and SNES games according instruction I found on the forum. I am using now MB 3.0.207.0 and GB 3.0.0.41 When I launch a Windows game it works normaly. But when I launch DOS, Playstation and SNES Game the WMC Windows is minimized and the emulator didn't start without any error message. I already check that emulator were working and that I can access to the game path via explorer. Please find hereafter the log. Thanks for your help MBClassic-179201402d714df294346c5a0254b589e48df1b.log
Solution Redshirt 1487 Posted September 17, 2014 Solution Posted September 17, 2014 It looks like MBC is trying to play that game as a video file. If you add your game folder to the library using UNC paths (\\Server\directory) you have to configure each game system in the GameBrowser server plugin config using the same paths. You can't have \\server\games in one location and H:\games in the other. 1
fidji 3 Posted September 17, 2014 Author Posted September 17, 2014 Hi Redshirt, Thanks a lot it was exactly the solution to my problem. I change in the MB Server all the paths from H:\games to \\Server\games And all the emulators are working
