denz 501 Posted January 19, 2022 Posted January 19, 2022 Have been away for a long time and finally back and for some reason some channels have no guide data. I removed the tuner removed the guide data added everything back but guide still empty. I am using Icetv from Australia. embyserver.txt shows (5).xmltv
Luke 42243 Posted January 19, 2022 Posted January 19, 2022 HI, did you check the contents of the xml to see if it has data at that particular day and time?
denz 501 Posted January 19, 2022 Author Posted January 19, 2022 (edited) I certainly did and while going through other days noticed some other channels are starting to have missing guide data. Downloaded the portable stable version and it has no issues all the channels are showing guide data. Is there something that I can nuke or do I have to reinstall everything is there a way to backup series records. Edited January 19, 2022 by denz
Luke 42243 Posted January 19, 2022 Posted January 19, 2022 Try running the refresh guide data scheduled task.
denz 501 Posted January 20, 2022 Author Posted January 20, 2022 No Luck If I try to map another channel data to these channels they are always black. If I do the same to other channels they get the guide data of that channel. I am also seeing these errors in the alerts section Exception of type 'SQLitePCL.pretty.SQLiteException' was thrown. at SQLitePCL.pretty.SQLiteException.CheckOk(sqlite3 db, Int32 rc) at SQLitePCL.pretty.StatementImpl.MoveNext() at Emby.Server.Implementations.Data.SqliteItemRepository.ExecuteWithStringFormatParam(IDatabaseConnection db, String query, String valueText, Int64[] values) at Emby.Server.Implementations.Data.SqliteItemRepository.DeleteItemsInTransaction(IDatabaseConnection db, Int64[] ids, Boolean containsFolders, Boolean supportsPeople, Boolean supportsChapters, Boolean supportsCollections, Boolean supportsMediaStreams, Boolean supportsListItems, Boolean supportsExternalDatabases) at Emby.Server.Implementations.Data.SqliteItemRepository.DeleteItemsInChunks(Int64[] ids, IDatabaseConnection db, Boolean containsFolders, Boolean supportsPeople, Boolean supportsChapters, Boolean supportsCollections, Boolean supportsMediaStreams, Boolean supportsListItems, Boolean supportsExternalDatabases) at Emby.Server.Implementations.Data.SqliteItemRepository.DeleteChannels(Int64[] idsToDelete) at Emby.LiveTV.LiveTvManager.CleanDeadChannels(Int64[] currentIdList) at Emby.LiveTV.LiveTvManager.RefreshChannelsInternal(IProgress`1 progress, CancellationToken cancellationToken) at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options)
Luke 42243 Posted January 20, 2022 Posted January 20, 2022 Please attach the complete emby server log. thanks.
denz 501 Posted January 20, 2022 Author Posted January 20, 2022 Deleted library.db now everything is working.
