Sarakha63 18 Posted January 17, 2022 Posted January 17, 2022 I don't really know if this issue is on client side or server side. But for example each time i change settings on android tv related to Homepage it defaults back to setting Collections and Playlists to visible on server settings for the user. And as the option is not available on the client, i have to go and change it back on the server... And it will stay off until another config change is made on the Homepage settings of the clients Regards
GrimReaper 4898 Posted January 17, 2022 Posted January 17, 2022 Not sure what are you referring to, can you elaborate a bit, what are you changing client-side?
Sarakha63 18 Posted January 17, 2022 Author Posted January 17, 2022 Anything i change on android TV in the application settings such as Homepage Settings, or else ------> will result in the Show Collections on homepage and Show Playlists on Homepage options for the user be reverted to True.
ebr 16337 Posted January 17, 2022 Posted January 17, 2022 1 minute ago, Sarakha63 said: Anything i change on android TV in the application settings such as Homepage Settings, or else ------> will result in the Show Collections on homepage and Show Playlists on Homepage options for the user be reverted to True. Thanks. We'll take a look.
FrostByte 5454 Posted January 17, 2022 Posted January 17, 2022 Reported in the beta section awhile back. Very annoying.
Sarakha63 18 Posted January 17, 2022 Author Posted January 17, 2022 Just now, FrostByte said: Reported in the beta section awhile back. Very annoying. but in fact i just made some lots of cross testing and the issue is also here with server stable and androidtv stable And i agree with you its very annoying
GrimReaper 4898 Posted January 17, 2022 Posted January 17, 2022 (edited) FWIW I can't observe same behavior on 4.6.7.0 stable/2.0.64 beta. Edit: Recreated, thanks to @FrostByte for assisting to narrow down under which conditions same occurs. Edited January 17, 2022 by GrimReaper Testing 1
ebr 16337 Posted January 17, 2022 Posted January 17, 2022 38 minutes ago, GrimReaper said: thanks to @FrostByte for assisting to narrow down under which conditions same occurs. And what exactly were those conditions?
GrimReaper 4898 Posted January 17, 2022 Posted January 17, 2022 (edited) 7 minutes ago, ebr said: And what exactly were those conditions? Server side: Playlists access enabled under User settings, but disabled in Home screen settings. ATV app: Untick any library in Settings>Home Screen Layout>Allow to appear... Playlists library is back on refreshed Home Screen and enabled in server-side Home Screen settings. Edited January 17, 2022 by GrimReaper Typo 2
FrostByte 5454 Posted January 17, 2022 Posted January 17, 2022 Other changes in ATV will do it too. I think just about any change that refreshes or changes the HS makes Collections or Playlists come back 2 1
Sarakha63 18 Posted January 17, 2022 Author Posted January 17, 2022 13 minutes ago, FrostByte said: Other changes in ATV will do it too. I think just about any change that refreshes or changes the HS makes Collections or Playlists come back Yes any change on ATV reverts back those two options to true. As they are probably not in the post made from atv to the server and server seems to set them to true..thats why i reported that in the server section at the beginning 1
FrostByte 5454 Posted February 24, 2022 Posted February 24, 2022 On 1/17/2022 at 11:27 AM, Sarakha63 said: Yes any change on ATV reverts back those two options to true. As they are probably not in the post made from atv to the server and server seems to set them to true..thats why i reported that in the server section at the beginning This appears to be fixed in .68 beta from my testing. 1 2
Junglejim 385 Posted February 25, 2022 Posted February 25, 2022 13 hours ago, FrostByte said: This appears to be fixed in .68 beta from my testing. Cool, this was annoying. Thanks @FrostByte For confirming the fix in the upcoming release. Also thanks to @ebr for fixing the bug.. Really looking forward to the next round of releases (server & apps)! Looks like the devs have been busy. Well done guys.
