mldardy 2 Posted January 17, 2022 Posted January 17, 2022 I installed an Emby server on my pc and scanned all of my libraries successfully. When I go to install Emby for Android TV, I enter the server address manually and I am unable to connect to the IP address for the Emby server I installed. What am I doing wrong or a step that I am missing?
Spaceboy 2573 Posted January 17, 2022 Posted January 17, 2022 9 minutes ago, mldardy said: I installed an Emby server on my pc and scanned all of my libraries successfully. When I go to install Emby for Android TV, I enter the server address manually and I am unable to connect to the IP address for the Emby server I installed. What am I doing wrong or a step that I am missing? have you allowed emby through the firewall on your pc? can you access emby from any other device?
seanbuff 1356 Posted January 17, 2022 Posted January 17, 2022 Is there a firewall on the Emby Server PC? Have you allowed connections or disabled that?
mldardy 2 Posted January 17, 2022 Author Posted January 17, 2022 Just now, Spaceboy said: have you allowed emby through the firewall on your pc? can you access emby from any other device? I'm not sure about firewall, how do I check that. I installed on my phone and can't get to it when I put in IP address.
mldardy 2 Posted January 17, 2022 Author Posted January 17, 2022 2 minutes ago, seanbuff said: Is there a firewall on the Emby Server PC? Have you allowed connections or disabled that? I don't know about a firewall. How do I check that? Not sure on allowing connections either, how do I check that?
mldardy 2 Posted January 17, 2022 Author Posted January 17, 2022 1 minute ago, seanbuff said: What OS did you install the server on? Windows 7
seanbuff 1356 Posted January 17, 2022 Posted January 17, 2022 https://support.emby.media/support/solutions/articles/44001849007-connectivity Follow the 'Troubleshooting Internal connections' section to add a Windows firewall rule.
mldardy 2 Posted January 18, 2022 Author Posted January 18, 2022 Thanks to all of your assistance. I was able to get this fixed.
Luke 42239 Posted January 18, 2022 Posted January 18, 2022 52 minutes ago, mldardy said: Thanks to all of your assistance. I was able to get this fixed. What was the solution?
mldardy 2 Posted January 18, 2022 Author Posted January 18, 2022 2 minutes ago, Luke said: What was the solution? I downloaded Emby Server on the shield and also followed the instructions on adding a firewall rule and that worked.
