tzic 2 Posted January 16, 2022 Posted January 16, 2022 Hello, I am located in Europe. How can I install Emby in my new Samsung QLED tv? Please advice
FrostByte 5453 Posted January 16, 2022 Posted January 16, 2022 Unless you live in the UK or Ireland you will need to use the USB method to install
tzic 2 Posted January 16, 2022 Author Posted January 16, 2022 Thank you very much for the reply. Can you tell me which version should I download? Should I use my VPN (set to Ireland) and try to connect?
FrostByte 5453 Posted January 16, 2022 Posted January 16, 2022 The USB method will always have the latest. However, if you prefer installing from the Samsung store it can be a little behind while the app goes through Samsung review. To install from the UK or Ireland Samsung store you will need to change the app region in your TV.
