cncb 25 Posted September 17, 2014 Posted September 17, 2014 All the times listed for my scheduled NextPVR recordings are displayed incorrectly in the web interface (display shows several hours early). I assume it is a time zone setting or something for the web interface but I can't see anywhere to set this?
Luke 42241 Posted October 17, 2014 Posted October 17, 2014 we need someone with a next pvr test setup to do a little debugging. @@Sven the dates & times need to be utc. that could the problem if the data from next pvr is coming back as local
Sven 136 Posted October 17, 2014 Posted October 17, 2014 (edited) @@Luke Those timings are normally already in UTC format. But I will check it this evening.. Edited October 17, 2014 by Sven
Sven 136 Posted October 18, 2014 Posted October 18, 2014 (edited) @@Luke Yes it's UTC time. It's something like "2014-10-17T20:20:00.0000000Z" Edited October 17, 2014 by Sven
Sven 136 Posted October 19, 2014 Posted October 19, 2014 (edited) @@cncb @@Luke A new version is online. Indeed the time was not fully UTC. Also changed something on the Debug Logging, so you will not get to much logging. If you only work with the Release cycle, you need to wait a little bit. ( I tested it on 3.0.5402.35559 ) Edited October 19, 2014 by Sven
