2ombieboy 3 Posted January 15, 2022 Posted January 15, 2022 hi having the issue again of buffering only on 4k. i watched 1 on my cube tv downstairs and that was transcoding instead of direct saying it was too large for stream or something like that. then upstairs it played fine direct stream apart from 3 or 4 times freezing and buffing. before going back to play flawlessly. i really don't know why. anyone shed any light on the situation Alan embyserver.txt
ebr 16309 Posted January 16, 2022 Posted January 16, 2022 Hi. Are the devices wireless? What is the bitrate of these items? It sounds like the network is not able to deliver them quite fast enough.
2ombieboy 3 Posted January 16, 2022 Author Posted January 16, 2022 Hi there all hard wired in via ethernet. and stats for nerds says bit rate of 82.7 this is playing back on the updated LG app on my oled Alan
ebr 16309 Posted January 17, 2022 Posted January 17, 2022 21 hours ago, 2ombieboy said: stats for nerds says bit rate of 82.7 82.7 Mbs? If so, that is probably too high for the hardware. Most likely bottleneck would be the ethernet port on the TV.
