Jukol 1 Posted January 15, 2022 Posted January 15, 2022 Hey all, I have installed Emby in a Jail (used the default TrueNAS plugin): TrueNAS Version: TrueNAS-12.0-U7 Emby Version: 4.6.7.0 I have mapped the folder /mnt/volume_main/main_storage/localData/Media/A to /mnt/volume_main/iocage/jails/Emby/root/media/A When I go the Jail shell and I go to the mapped folder (/mnt/volume_main/iocage/jails/Emby/root/media/A) I can see my files. I can also modify the files here from the Emby Jail Shell. When I go the the web admin of Emby and I am trying to add a new libary no files are found. I tried 2 things: 1) use the navigation click on "/", click on "media", click on "A" this doesnt even safe because when I click on "A" the navigation possbilities disappear and I am left with the search bar. I cant safe at this point or do anything. 2) when I manually type /media/A I can safe the library but the scan does not bring up any results. Any ideas?
Solution Luke 42237 Posted January 16, 2022 Solution Posted January 16, 2022 Hi, have you taken a look at this?
