JuJuJurassic 50 Posted January 14, 2022 Posted January 14, 2022 Hi all, I suspect a really easy question, as I think the answer is no. Does the iOS client support support camera uploads, and if so, where is it? thanks
Luke 42242 Posted January 14, 2022 Posted January 14, 2022 Hi, yes it does, on iOS 11+. Have you explored the settings in the app?
JuJuJurassic 50 Posted January 17, 2022 Author Posted January 17, 2022 Excellent I found it, and they uploaded, thank you, One question, I got 4 new libraries, all identical called camera uploads. What did I do wrong? and how do I reduce it to 1? Is the following possible? We have a family holiday coming up, is it possible to have a single camera upload area that only uploads photos while on holiday from multiple devices? After the holiday I'll transfer them to a little library and disable all but me and my wife's uploads. Thanks
Luke 42242 Posted January 24, 2022 Posted January 24, 2022 Are you able to remove the extra ones from emby library setup?
JuJuJurassic 50 Posted January 24, 2022 Author Posted January 24, 2022 Hi Luke, I tried removing 1, but all 4 disappeared. I then re enabled uploads from the client and now have 9 upload libraries, so I think I'll disable it for now. any suggestions?
Luke 42242 Posted January 25, 2022 Posted January 25, 2022 OK we'll take another look at trying to chase this down. Thanks.
