Zodler 18 Posted January 13, 2022 Posted January 13, 2022 (edited) Every time I go into the Reports plugin which is often I have to set the View and Filter which is very tiring. They are not saved and are reset. They should get saved automatically or have a button to save them and reload with those settings. Edited January 13, 2022 by Zodler
Luke 42255 Posted January 13, 2022 Posted January 13, 2022 Hi, yes it's not a bad idea. Thanks for the feedback. 1
